Kicker 11HS8 - Compact powered sub
Results 1 to 11 of 11
This is a discussion on Kicker 11HS8 - Compact powered sub within the Electronics/Car Audio forums, part of the Interior Mods category; Anyone have experience with this unit? I'm wanting to find a powered sub to put under the front passenger seat ...
    Registered User mikal52waltincec's Avatar
    Jun 2013
    Texas
    Anyone have experience with this unit? I'm wanting to find a powered sub to put under the front passenger seat and this seems to be the best I could find. If you've had experience with it or another that would fit in that space please let me know.
    Kicker 11HS8 Hideawayâ„¢ compact powered subwoofer: 150 watts and an 8" sub at Crutchfield.com
    Jun 2013
    Texas
    After reading more reviews it sounds like this is a good unit for its class, but I don't think it'll hit low enough frequencies for me to be pleased with it. So I will be finding an 8" or 10" to put in the trunk.
    Registered User wrx-V's Avatar
    Dec 2012
    Fort Lauderdale, FL
    Take a look at sound ordnance b-8pt or b-8ptd
    '02 Sentra SE-R Spec V SOLD
    '13 SWP WRX 4-door
    -Invidia turboback, Grimmspeed EBCS,-TP Stage 2-
    2013 Subaru Impreza WRX
    Jun 2013
    Texas
    I looked into those too, but all of the Kicker reviewers said they switched from the sound ordnance because it was terrible.
    Registered User Yobfriend's Avatar
    Oct 2013
    Colorado plains
    Registered User Wrxchick1676's Avatar
    Feb 2014
    NJ
    I miss my system .. I need that bass but I also need my trunk . I was thinking of an 8" sub . I need it mounted on the side n not in the middle of my trunk
    Jan 2012
    New Jersey
    Thats a lot for a low profile sub (kicker). Although any sub should be better then none at all. If you are going to go with a lowprofile get a cheaper one. I still need to install one on my wrx but I need to fab up a speaker enclosure to fit in the corner of my trunk.
    CFLip2x 2012 WRB WRX Build
    Feb 2014
    NJ
    Quote Originally Posted by cflip2x View Post
    Can you make 2 n send me one 😜
    Registered User WREXXY's Avatar
    Oct 2012
    CT
    idk what your budget is, but this is my setup:
    Sundown Audio SA 8v2 $180
    Sundown Audio SAZ-1000d $280
    0.75 cuft aeroported box built by davetheboxguy tuned to 33Hz $180
    ^^that should hit low enough
    Feb 2014
    NJ
    That would look good in my truck if it was able to fit in the corner n not in the center
    Feb 2014
    NJ
    *trunk*
