Car keeps dying!
Results 1 to 15 of 18
This is a discussion on Car keeps dying! within the Electronics/Car Audio forums, part of the Interior Mods category; So my car will never hold a charge overnight. Every morning I have roll start in the the parking garage. ...
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    Car keeps dying!
    So my car will never hold a charge overnight. Every morning I have roll start in the the parking garage. I went and had diagnostics run on the battery and they said it's good.
    Now my head unit won't turn on either so I'm thinking that could be the cause of my problems. And advice on what I should do? I was gonna rip out the unit to check connections but I would be very surprised if one was bad. I have an aftermarket Kenwood xdc-794 head unit and a boss subwoofer.
    Sent from my Nexus 7 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    Registered User chutoyy's Avatar
    Sep 2012
    Seattle-ish, WA
    I had the same problem, but after I drove the car non-stop for about an hour (to fully charge), I haven't had a problem. Try that, and if that doesn't work than you have excess power drain.
    2013 WRX Plasma Blue Pearl
    Aug 2012
    Tucson, AZ
    i had a problem like that when I had subs in my lancer. the problem was the line out receiver was "telling" the amplifier ti always be on. turn your car off and check for a light on your amp. of course with a charged battery
    May 2007
    New Orleans
    Yeah the sub has a built in amp. And I looked at that and there is no light on. The battery is 6 years old does it make sense that it would do that?
    Sent from my SCH-I545 using Tapatalk 2
    STU 17
    WATCH THIS
    May 2007
    New Orleans
    Also if it is a bad line out how do I fix it?
    STU 17
    WATCH THIS
    May 2007
    New Orleans
    Bump please!
    STU 17
    WATCH THIS
    Sep 2012
    Seattle-ish, WA
    Quote Originally Posted by SubaruWRC View Post
    Even though the battery tests fine, it may be on it's last leg...
    Get the battery fully charged, then see if you can start it the next day... If not, get it charged again and unplug all aftermarket accessories (Radio) then try again in the next day... If none of this works, buy a new battery. If you have the same problem w/ a new battery, you have parasitic drain somewhere.
    May 2007
    New Orleans
    I'm gonna unplug the battery terminals overnight and if the battery is dead in the morning it has to be the battery right?
    STU 17
    WATCH THIS
    May 2007
    New Orleans
    I also just had my car open source tuned about a mont ago. Could this be a problem?
    STU 17
    WATCH THIS
    May 2007
    New Orleans
    Last piece of info. My friends played a prank on Me and left the lights in my car on. My battery was completely dead. Like nothing would turn on could this have killed my battery?
    STU 17
    WATCH THIS
            MainFrame's Avatar
    Austin, TX
    Yes.. most batteries don't like being fully discharged, especially when they are already several years old. It's time for a new battery. If you want to check if some of your accessories are hooked up wrong and draining power use a DMM and test via the fuse box with everything turned off. If it's pulling current you have a problem.
            MainFrame's Avatar
    Austin, TX
    Warning: require_once([path]/includes/class_mail.php) [function.require-once]: failed to open stream: Permission denied in [path]/includes/functions.php on line 1379
    Fatal error: require_once() [function.require]: Failed opening required '/home/clubwrx/public_html/forums/includes/class_mail.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/clubwrx/public_html/forums/includes/functions.php on line 1379
    thanks club
    May 2007
    New Orleans
    The battery is only one year old however.
    STU 17
    WATCH THIS
            MainFrame's Avatar
    Austin, TX
    Deeply discharging the battery (depending on the type of battery) is going to damage it regardless, so it's possible that your battery is ruined, if it's one or six years old.
    May 2007
    New Orleans
    Yes I forgot it was replaced. Forgot that it wasn't the original battery.
    STU 17
    WATCH THIS
