Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 94
This is a discussion on iPad mini Install Idea within the Electronics/Car Audio forums, part of the Interior Mods category; Update ...I hate body filler... About 90% done, just have to do the final body work. I started a little ...
  1. #61
    Registered User naked_dave1's Avatar
    Nov 2011
    Appleton WI
    Update
    About 90% done, just have to do the final body work. I started a little but had to go out of town so I did what I could and put a coat of primer on. Never worked with body filler and I can't get it to do what I want. I have tight corners and spaces to work with which doesn't help. I try to fill some small holes but can't get the filler to stay or fill in the hole completely. Another issue I'm having is getting a smooth transition between the body filler and the plastic. I used rougher 80 grit sand paper to get the basic shape, then 140, the finer paper. So, any tips would be helpful!
    Also, I cracked the solder connection on the plug while test fitting the suede. It still works and charges when it's full in, but as soon as I start to take it out it looses connection. I'll have to see how long it'll last and what else I can do about it. I might take it out and re-solder it and make that joint stronger.
    You can click on the pic to see the larger version to see my crappy body work lol
  2. #62
    Registered User starkall's Avatar
    Sep 2010
    Use standard bondo filler to rough the shape you want, 80g to 140g or whatever, then apply a Glaze coat filler over the bondo to fill the pinholes and deep scratches, sand that with 240g and work upto 800g. Then prime. If you have 140g scratches in it the primer and paint will shrink and you'll see the scratches when finished. The Glaze coat will work much better.
  3. #63
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    That is awesome!
  4. #64
    Dec 2012
    wow. your doing a great job. keep it up.
  5. #65
    Nov 2011
    Appleton WI
    Update
    bondo, sand, bondo, sand, primer, dry, sand, bondo, sand, primer, dry, sand, primer, dry… It's very time consuming doing body work to make it look nice. But, it's getting there!
    I'm trying to figure out my plan of attack for getting the suede in there. I'd like to cover the whole inside of the pan, but I don't think I have the skills or know how to do that and make it look nice. I'm looking around for local upholstery shops to see if they could do it. Any tips or ideas??
    The lightning 90° adapter broke at the solder joint. I was going to fix it, but I might try using the cable that came with the iPad. It's looking like it'll just fit without hitting the left side. The cable also looks stronger in case of bending it too far when I take it out.
  6. #66
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    everything looks good. for the suede, could you glue it down?
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: WTF Tuning Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
  7. #67
    Nov 2011
    Appleton WI
    Quote Originally Posted by spirited09wrx View Post
    Yeah, it'll be glued down. But the hard part is getting the entire inside of the pan covered because of the complex and tight curves.
  8. #68
    Registered User 2008subaruguy's Avatar
    Apr 2012
    Re: iPad mini Install Idea
    You could use a upholstery spray glue. Tape the areas you don't want glue then spray the pan and the back of the suede. Gently set it in. Just an idea. Good job so far!
    Sent from my HTC6435LVW using Tapatalk 2
  9. #69
    Registered User hindude's Avatar
    Apr 2012
    NW Suburbs, Chicago
    This is blowing my mind! It looks great! Does the ipad fit in there nice and snug? Can you still point your vents in all directions like before the modification?
    Also, have you done any driving around with the ipad in there and turned on? I'm curious about what kind of glare you might get. Usually cars have a large cowl to make sure the screen is always visible.
    Keep up the good work!
    2012 Limited World Rally Blue Pearl Subaru Impreza World Rally Xross Sedan ...
    ...On order since 4/14/2012; Received VIN 7/4/2012; ETA 8/6/2012; Delivered 8/9/2012
    OTS AP Stage 1 9/15/2012
  10. #70
    Mt. Laurel, NJ
    Wow that looks better than I ever imagined it would. Kickass.
  11. #71
    Aug 2012
    N. Shore, MA
    this
    Sent from my iPhone using Forum Runner
    2012 WRX Premium Hatch, Stage 2
    Ice Silver Metal
  12. #72
    Registered User drkhead's Avatar
    Aug 2012
    Amherst, MA
    nice progress!
  13. #73
    Nov 2011
    Appleton WI
    Quote Originally Posted by hindude View Post
    Thanks! The iPad does fit very snug, drove about 400miles with it in so far. I've drifted in the snow, hit big bumps and it doesn't move or rattle, even without the suede in, just the primed piece. As far as glare, it's very minimal when the screen is off, when it's on, I do not notice it. from my view in the drivers seat, what I see is the part of the passenger window. The vents work normally, just smaller
  14. #74
    Nov 2011
    Appleton WI
    Would there be any interest in me getting these mass produced in a sold plastic like the stock bezel so it'd be almost plug and play? If so, how much would you pay for something like this realistically?
    Similar to this?
    The STiPad Project - Put an iPad in your Subie! - NASIOC
  15. #75
    Registered User devyn339's Avatar
    May 2011
    berwick pa
    id def buy one !
    Sent from my SCH-I510 using Tapatalk 2
