iPad mini Install Idea - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 102
This is a discussion on iPad mini Install Idea within the Electronics/Car Audio forums, part of the Interior Mods category; It's coming right along!...
  1. #46
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
  3. #47
    Registered User naked_dave1's Avatar
    Nov 2011
    Pewaukee WI
    Test fitting in the car. Looks like everything clears. It's going to be a very tight fit for the radio as the depth is shallow and the back of the radio is hitting...
  4. #48
    Apr 2012
    NW Suburbs, Chicago
    wow, this is looking really great!
  6. #49
    U.S. Combat Veteran (3ID) Stu_Gotti's Avatar
    Jan 2011
    Southern Maryland
    You're doing a phenomenal job, dude. Looks like it'll come out very nice, anxious to see the final results.
    My Build : IAG Closed Deck Stage 2.5 ~ 427hp/399tq | Facebook | I may appear calm, but in my head I've killed you three times
  7. #50
    Aug 2012
    N. Shore, MA
    *subscribed*
    2012 WRX Premium Hatch, Stage 2
    Ice Silver Metal
  8. #51
    Registered User rurso01's Avatar
    Oct 2012
    yeah subscribed as well. I'm quite impressed!
    2013 SWP WRX 5-Door
    2005 OBP WRX 4-Door SOLD
  9. #52
    Dec 2012
    nice job man. cant wait to see the final product.
  10. #53
    Nov 2011
    Pewaukee WI
    Update:
    Created the final tray. This time the results where a bit better. I taped up the whole table thingy I was working as the paper bags I used last time were not flat enough. I pre cut and test fitting two sheets of fiberglass so it would be stronger and easier than multiple little pieces of it. Before I glassed I test fitted the magnets buy setting them on the iPad and see where they where the strongest. I marked them so I knew where they would go once I got going. I still had issues on the sharp corners with the fiberglass and resin not sticking and getting air bubbles. So along the edge of the iPad there where air bubbles and once I took it out you could see the gaps.
    Got the vents and the tray glued in with epoxy to the radio bezel. I still have yet to glue the bar where you see the gap between the tray and vents.
    Got the part I was dreading the most, fitting the radio. I figured it'd be the hardest as I have to match the radio and tray up in 3D space so a lot of things could go wrong and not line up. But, thankfully everything did! I had to create my own brackets so everything would position correctly. I took some measurements the best I could and created the mounts out of some aluminum. It was thin so it was flexible to bend in the right positions. In the photos I wanted to test fit everything so the single DIN radio does not have the little black bezel on so it might look a little rough on the inside of the tray by the radio.
    Suck the iPad on to check the clearance to make sure the radio did not hit the back of it. Everything is fitting like a charm and everything has been very tight for clearances so far. The radio just fit far back enough, don't think it could go back any farther unless you did some heavy modifications or titled the radio on a good angle.
    Still can't think of an elegant and durable solution for the lightning cable. So what I'm going to do for now is just have the cable that came with the iPad and have it hanging out. I'll plug it into the iPad then snake the cable back thought the hole when I want to mount it.
    If any of you plan on doing something like this, make your life way easier and sick the radio somewhere else. I would be done by now if I just created the iPad tray like you saw in the videos I posted...
    I hope to have most of it done tomorrow. can't wait to get this done, it's been a bit overwhelming! But now that everyone is interested I have to finish it haha. And I'm doing all this with very limited tools (dremel) in my apartment or the basement.
  11. #54
    Nov 2011
    North GA
    Very impressive! Are you worried about heat dissipation at all?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
  12. #55
    Nov 2011
    Pewaukee WI
    Quote Originally Posted by michaelwfox View Post
    Thanks! Not really, I rarely use the front vents for heat. Use them for air condition and the cold air is fine on the electronics.
  13. #56
    Palmyra, NJ
    Wow! Pretty impressive. Are you going to paint the mount to match as well?
  14. #57
    Nov 2011
    Pewaukee WI
    Yeah, going to try and match as close to factory as possible. I'll also be putting some suede where the iPad will rest so it doesn't scratch or vibrate.
  15. #58
    Apr 2012
    NW Suburbs, Chicago
    That's looking really nice! In the 6th pic you just posted, I can see the black rectangular tubing for the HVAC system that is just behind the bezel. Does that part interfere with your design? Are you removing it or keeping it in the final product?
  16. #59
    Nov 2011
    Pewaukee WI
    Quote Originally Posted by hindude View Post
    Thanks! It will stay, I just took it out because it was easier to position and move the radio. I'm trying to keep everything as stock as possible so it could be easily swapped out for the original. The only things I changed was the radio bezel and vents, and I bought a spare vent that I've been using.
  17. #60
    Nov 2011
    Pewaukee WI
    Update
    Looks like I'll be able to use the 90° connector I have. The actual male part on the lighting plug is short enough that it doesn't need to bend much to get the iPad in. I had to trim a bit on the PC board to make it fit and I used hot glue to keep it in place. I figured hot glue would give a little flex, and it does. I don't think in the long run it will put much strain on either the iPad port or the plug.
