Results 1 to 8 of 8
This is a discussion on Satellite radio help! within the Electronics/Car Audio forums, part of the Interior Mods category; I have a 2010 Wrx, which I bought private party. Previous owner had installed a Kenwood DNX6960 head unit. I've ...
    Aug 2012
    I've done a lot of research and even asked kenwood. I know I need an adapter and the serius tuner.
    My main question is can I still use my stock antenna on the back of the car? I dont want to use the little magnetic one if I dont have to.
    Have any of you been able to use satallite radio with your stock antennas with aftermarket HU's? Thanks!
    Registered User squiRe2001's Avatar
    Jun 2012
    Northeast, PA
    Re: Satellite radio help!
    Last I knew it didn't have a stock sat. Antenna? I could be wrong though
    Sent from my Galaxy SIII using Tapatalk 2
    2013 WRX Sedan DGM
    -Paul
    Aug 2012
    Quote Originally Posted by squiRe2001 View Post
    Well I assumed it did considering the stock radio says satallite on it....
    Jun 2012
    Northeast, PA
    I assumed to when I got mine too. But I was told it sat ready
    2013 WRX Sedan DGM
    -Paul
    Registered User Stawgn10's Avatar
    Apr 2010
    Colorado Springs
    My sat antenna is in the upper right corner of the windshield.
    2010 WRB WRX wagon
    Aug 2012
    Ok, let me take a step back.
    The black antenna on the rear of my 2010 WRX, that swivels forward and backward, is it for AM/FM and Satellite? Or AM/FM only?
    I may have misunderstood and this would make sense.
    Apr 2010
    Colorado Springs
    I believe the back antenna on top of the car is am/fm only.
    2010 WRB WRX wagon
    May 2012
    Yes the antenna on the back is for AM/FM only. You're going to need to install the satellite antenna that came with the system.
