Running new speaker wires inside the front doors of a 2012 WRX Sedan
Results 1 to 11 of 11
This is a discussion on Running new speaker wires inside the front doors of a 2012 WRX Sedan within the Electronics/Car Audio forums, part of the Interior Mods category; Has anyone run both a 14 gauge and 16 gauge wire through the front doors of a WRX yet? From ...
    Registered User gunz4me's Avatar
    Dec 2011
    Louisiana
    Has anyone run both a 14 gauge and 16 gauge wire through the front doors of a WRX yet? From what I am see, it appears that I can get away with disconnecting the boot at the body side outside the kick, disconnecting the molex plug in the kick, pulling the molex out between the door and the body, then snaking the wires through the boot. I'd be willing to bet that typing it out is way easier and faster than actually performing that task.
    My reason for doing so is that I am planning on running my midrange and tweet active, and I think the factory wire is a tad bit small for the job. Also, I don't want to hack up any of the factory wires to make the vehicle easier to return to stock. Further more, no matter how you slice it, I'll still be running at least ONE new wire into the door due to the fact that the factory tweeter is split off the existing wire.
    Now for a totally off the wall point... Why is it when I keep all the stuff pristine to return the vehicle back to stock, I never have the need to return the vehicle back to stock? Conversely, when I don't preserve the OEM parts to return the vehicle back to stock, I end up wishing I could have returned the vehicle back to stock.
    Registered User Joshmath's Avatar
    May 2012
    Fairbanks, Alaska
    Hello, coming from some shop experience I will give you my personal account of your situation. I have in all my time as an installer in a shop never needed to run new speaker wiring because a wire looked like it wasn't enough. If you are going for a sound competition sound complete with a 4 channel amp to your speakers and looking for the most sound quality you can get I would go the route you are going. Running through the boot is absolutely the only correct way to do that install. Having wires hang out your door or tied up around the boot is a bad choice, leaves the wire out to the elements. A hook tool will work well for you to disconnect the boot, should be as simple as hooking in and pulling out, may require a little force. Zip-ties are your best friend when it comes to this kind of work so make sure you zip tie to some factory harnesses underneath your dash coming from your deck.
    As for your second point, that just seems to be how it is haha. Everything works great when you have a backup plan! Take pictures if you have time for others to see on the forum and get an idea of your DIY install. This way you can help some others who are stumbled or if you have a question someone can give you a more direct answer from the pictures. (This wiring stuff can be kind of confusing sometimes).
    Dec 2011
    Louisiana
    Well, for the last 5 years or so, I became spoiled with active crossovers and time alignment. Besides, if I were to go passive and install the crossover inside the door while tapping into the factory wires, Murphy would bite me in the bum and make a capacitor, resistor, or inductor break loose from the passive crossover's circuit board. The worst thing I ever encountered with installing the passives in the doors was having the circuit board itself snap. For some reason I am snake bit when it comes to installing crossovers in the doors because they don't like that sudden stop from closing the door.
    This is what is set to go in the vehicle:
    HU - Pioneer DEH-80PRS
    Amp - Alpine PDX V9
    Front Comps - Genesis Profile 16 run active
    Sub - a Digital Designs 1508 that I have on hand. I'm going to try to make it somewhat easy to remove for the 2 times a year I fold the seats down to transport longer things back from Home Depot.
    I'm on the fence about going with a sealed 10" sub and the Audio Integrations enclosure because I have yet to be impressed with the low frequency response of a single, sealed 10" sub that modeled with a predicted F3 near 60 Hz.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I ran,I think 14 gauge,speaker wire through the front & rear doors.
    When you remove the door card you will find the existing bunch of wires taped to the opening of the boot. I made a small nick in the tape & ran the wire through it using a coat hanger. The boot can be removed from either side. It took me a while to figure out how to put it back though. There is only one way to reinstall it. You will find ,if I remember correctly, 3 grooves,one at 12 o'clock ,the others at 4 & 8 o'clock. They have to match up to the white plastic frame.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Moderator Donkey's Avatar
    Da boonies,Va
    I wouldn't disconnect the door boot unless you absolutely had too. I prefer using an electricians fish tape to the coat hanger.
    2002 FORESTER S
    1998 FORESTER S
    Quote Originally Posted by Donkey
    This
    Resident Tuner @ WTF Tuning
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by rage-wrx View Post
    This is more or less what I did in my 02..
    Dec 2011
    Louisiana
    One of my installer friends asked me if I still had some super long zip ties. Then he said he would come and pull them through for me if I ran into problems. I call that a win.
    Registered User WREXXY's Avatar
    Oct 2012
    CT
    old thread, but how did this go? i have to do this in about a week
    Dec 2011
    Louisiana
    I hated every minute of it but was able to fish the wires through using super long zip ties taped to the wire.
    As for the PDX-V9, it exhibited noise and is gone. The DEH-80PRS, while a good processing unit, has less than useless BlueTooth. Then, making matters worse, within the last two weeks the pico fuse popped upon restarting a stalled car. So that is next on the docket to go!
    Oct 2012
    CT
    awesome i have a ~ 3 foot one so that'll do the job, and i ended up going with a polk audio 4 ch amp so hopefully it isn't noisy. almost got the alpine though
