They should be buying you the new part...
Subaru OEM Parts
This is a discussion on Radio Trim Replacement within the Electronics/Car Audio forums, part of the Interior Mods category; I got a nav installed in my car and the people messed up the radio trim. Does anyone know where ...
I got a nav installed in my car and the people messed up the radio trim. Does anyone know where I could buy a new part?
Subaru OEM Parts
They are. I'm just trying to find the part. I was not able to find the part on that site.
I believe you're looking for part # 12, may not work if your new nav unit is non standard size - I've heard of folks using the JDM bezels for larger nav displays.
If it is standard double din you can buy oem bezels on eBay, pretty pricy though.
I think you might have it backwards.....From what I have read, the USDM bezel/radios are slightly wider than standard double din size. If your aftermarket HU is standard double din, you need either a small adapter/filler plate, or the JDM bezel (the JDM ones are real pricey).
Stink-Eye Mob #39
N.E.R.D. Operative #8
