Thanks I will try that I have it on the passenger side on the dash and I hate looking at it.
This is a discussion on anyone have a avic x940bt installed? within the Electronics/Car Audio forums, part of the Interior Mods category; I've got a great trick for you... I removed the surround around my gauge cluster, pulled the gauge cluster out ...
I removed the surround around my gauge cluster, pulled the gauge cluster out and stuck it upside down as far back as I could reach up above the cluster. It's all foam, so the GPS signal goes right through it. There isn't any metal above it to jack your signal up. I never had problems with GPS signal unless I was in a canyon
2012 Wrx SWP Hatch-Traded
2013 Limited ISM Hatch -Current
I just stuck mine on top of an air vent behind the head unit and under the dash in the defroster area. It was a bit of a reach but works like a charm.
2011 STi Build LogOriginally Posted by Trainrex
