Android Music Player Turns On in Car! - Page 2
Results 16 to 30 of 35
This is a discussion on Android Music Player Turns On in Car! within the Electronics/Car Audio forums, part of the Interior Mods category; Hmm. I have had a few occasions where the phone would continue to play through it's crappy speaker after I ...
    Jan 2012
    Philly Area
    Hmm. I have had a few occasions where the phone would continue to play through it's crappy speaker after I turned the car off, but unless I left the car in BT on the stereo, I haven't had the phone just start playing music when I started up.
    HTC Evo 4g by the way.
    - Will
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Annihilator817 View Post
    The solution is obvious.
    Just don't leave the head unit set to BT when you turn off the car. If you left it set to FM, USB, CD, etc, or even if you just had the radio off, you would not be hearing music from your phone when you start the car. If you left it on FM, you would hear the radio when you start the car.
    And just let the phone play away, draining the battery in the process? No thanks.
    Registered User Annihilator817's Avatar
    Oct 2011
    New England
    That won't happen as long as the HU is not set to BT when you start the car.
    Good judgement comes from experience, and experience comes from bad judgement.
  6. #19
            MainFrame's Avatar
    Austin, TX
    Yea, makes sense that it wouldn't launch the player with nothing to connect to.
    On a similar line of thinking, why not just turn off BT on your phone? Simply having it on drains the battery.
  7. #20
    Oct 2011
    New England
    Because he wants the BT calling to work.
  8. #21
            MainFrame's Avatar
    Austin, TX
    Bleh.. screw calling, I use the car to drive.
  9. #22
    Jan 2012
    Philly Area
    The BT connects to the stereo for calls no matter what setting the stereo is on.
    - Will
  10. #23
    Oct 2011
    New England
    Correct.
    But MainFrame asked "why not disable BT on the phone"
    BT won't work if the BT radio on the phone is disabled.
  11. #24
    Registered User jas280z's Avatar
    Mar 2012
    WNY
    Guys, the issue is not music playing through the stereo, or even actually playing from the phone (I always have the media volume all the way down on my phone). It is simply that the player starts, and plays the songs on my phone silently, but eats my phone battery. This happened no matter what the head unit was set to, as soon as the phone connected to the Bluetooth. The stock android music player is a pain to turn off. It doesn't have an off button per se, you just have to hit back a bunch of times and hope that it actually shut down, and is not running in the background.
    I figured out how to disconnect the media portion of my phone, but keep the Bluetooth active. So that has pretty much solved my problem. It is not perfect, but it is much better than it was.
  12. #25
    Registered User 722ish's Avatar
    Oct 2004
    I'm not sure why you would be against rooting. All of my recent phones (Evo 4g, Evo 3D, and now Galaxy Note) have benefited greatly from root applications. Improved performance, and nearly doubled battery life on each device. Not to mention how great it is to be able to nandroid backup. If anything happens to the phone you can instantly restore everything exactly how it was, even onto another phone if yours was lost/stolen.
    Sorry, not to sidetrack but are you talking about doubling the note battery?
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
  13. #26
    Oct 2011
    New England
    I'm surprised people still use the android player anyway, the steering wheel controls don't even work with it, iirc.
    Download 'double twist' from the Market and use that, and you'll have no more issues.
  14. #27
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    you could also look into getting a task killer to stop unwanted processes from running. Granted, without rooting the phone, it will be a crippled task killer, but it will be able to completely stop running processes like the media player.
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    2015 Dark Grey Metalic STI Limited - Stock (womp womp).....for now
    2011 Spark Silver WRX hatch - Returned to stock and traded in
  15. #28
    Jul 2011
    Cloud City, Bespin
    Quote Originally Posted by 722ish View Post
    Yes....if you root the phone, remove all the unused/unneeded aps, and make a few other small adjustments you can significantly improve battery life of most smart phones. This can either be done manually, or by replacing the ROM with a custom ROM that has it all done for you.
    Stink-Eye Mob #39
  16. #29
    Mar 2012
    WNY
    I did have a task killer, but one day one of the tasks it started killing was the internal app to run the cell antenna. Not good. So I did a factory reset and only reinstalled the apps that I actually use. That alone doubled my battery life.
  17. #30
    Jul 2011
    Cloud City, Bespin
    I was not meaning one of those task killers that you keep running in the back ground to manage your phone, but one that you start, kill processes, then kill the task killer. The one I use is called ES Task Manager, and it works great....it can even change what aps start at startup if you reboot your phone.
    Stink-Eye Mob #39
