6.5" Front / 5.25" Rear
Spacers should be used because most aftermarket speakers have a larger depth.
Tweeters should be placed in the A-Pillar / Kick Panels for best SQ
This is a discussion on Replacing door speakers (question) within the Electronics/Car Audio forums, part of the Interior Mods category; I've been doing a lot of reading on the forums and have not been able to decipher a clear answer. ...
I've been doing a lot of reading on the forums and have not been able to decipher a clear answer. I'm looking to upgrade all the door speakers an have some questions below.
1) what size is each door speaker?
2) I've read that they sell adapters for aftermarket door speakers to put diff sizes. Do I need this?
3)what door speakers fit using the stock configuration?
4)Can I use stock housing for the upgraded tweeters or do I need to buy an adaptor?
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
2012 WRX Hatch World Rally Blue
L.E.D Lights Swap, KB STS, Cobb Shifter Knob, Kenwood DDX 719 7", H.I.D.'s
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
The same sizes should work. AI makes great stuff.Originally Posted by Jabbathewhat
I wouldn't bother with the rear speakers until you've upgraded your headunit, front speakers, amp, sub, and proper sound deadening installed. They are just fill anyway, and you'll get more out of the other stuff mentioned.
Sent from my Droid using Tapatalk
For the 2011/2012 both front and rear speakers are 6.5".
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
The Big 2011/2012 Mod Thread
"Just Leave me alone. I know what I'm doing"- Kimi Räikkönen
What speakers did you guys end up using and did you need the spacer adapters.? Also where did you install the dynamat at?
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
Staging. How much time do you spend in the rear seat?Originally Posted by Jabbathewhat
Here's a good guide:Originally Posted by Jabbathewhat
NASIOC - View Single Post - STI sound deadening, new tutorial
I will deff check out the links for that. I thought upgrading the rears would add to the sound as a whole. Also what speakers did you end up using?
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
Focals
But they cost an arm and a leg.
I have boston pros, I was able to re-use the spacers that the OEM speakers came in and put the tweeters in the OEM location with a little modification. I dynamatted the whole door, it's a little overkill but it sounds fantastic
Stink eye mob #727
2011 WRX DGM Hatch, Protuned Stage 1
AI just came out with those spacers.Should be good.
I would have ordered them but I got mine from PVC Speaker Adapters - CNC Machined - In Stock or Custom Made already.
The tweeters I got did not fit in the stock sail.You may have to do some modification to them to get them to fit there.Or like suggested earlier put them in the A-pillars or kick panels.
I have Monster RX-6s for coaxial speakers.Also dynamated all 4 doors & hatch area.
-Tony
2011 WRX WRB Stage2
2012 FXT DGM
Yes, but they pull the stage away from the front of the car, where you spend 99% of your time. Until you've done the other stuff listed (including deadening like the link I provided), your money is better spent elsewhere.Originally Posted by Jabbathewhat
Speaker brand is a personal thing, similar to car exhausts. Your best bet is to hit up a few car audio stores in your area with a broad collection of music you'd listen to, and listen to what they have on display. Pick the speakers you like best.
I really wanted a set when I bought my speakers, but I was on a budget, and just couldn't swing them at the time. When I get a raise, I will likely be swapping out my Alpine Type-Xs for them or a set of Image Dynamics.Originally Posted by Mikie13
If you're going to spend the coin on quality parts, install them properly.Originally Posted by rage-wrx
Not likely "overkill". Inner skin? Outer skin? Both?Originally Posted by jd92677
Side question: does the 2012 radio have a pre-out to hook up a sub amp or will I need to use a LOC?
-Chris Z.
12/27/11 - Ordered
01/16/12 - Received
