iPhone 4S + Bluetooth - Page 2
Results 16 to 30 of 35
This is a discussion on iPhone 4S + Bluetooth within the Electronics/Car Audio forums, part of the Interior Mods category; hrm..... something is amiss here.... Which HU do you have nav/non-nav? It almost sounds like it is stuck in the ...
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    It almost sounds like it is stuck in the part of removing the BT idents.
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    2015 Dark Grey Metalic STI Limited - Stock (womp womp).....for now
    2011 Spark Silver WRX hatch - Returned to stock and traded in
    Registered User SRTSamb's Avatar
    Mar 2011
    Virginia
    Quote Originally Posted by DemonWRX View Post
    It's very frustrating! I have the stock non nav HU.
    Currently nothing in the memory reg that I can tell. It will initially connect and read my iPhone named "iPhone" but then after I shut it off and then back on its gone and can't connect unless I reset the connection or delete re add etc
    Any way to "reset" the Bluetooth memory? Maybe I'll pull the battery
    2011 OBP WRX::Invidia Catless DP::Cobb CAI::TP 93 STG2::KB STS::Perrin Sways::
    Jul 2011
    Cloud City, Bespin
    Looks like you may need to re-name the phone (odd right?).... here is the other thread that had all that info in it...
    Got Iphone4 replacement doesnt seem to be pairing correctly with bluetooth now
    Stink-Eye Mob #39
  6. #19
    Registered User Railroader's Avatar
    Mar 2011
    Yonkers, NY
    Quote Originally Posted by brew04 View Post
    In the bluetooth connection options for the pairing with your HU, you should be able to choose to be a headset or media player or both. If you choose only headset, when your phone detects the car it shouldn't start your iTunes and start playing music. At least this is how it works with my Samsung Charge and its media player.
    I'll look into that, I just got my iPhone 4S, once it's ready I'll try to pair it to the car.
    ~::2011 Subaru Impreza WRX Limited WRB::~
  7. #20
    Mar 2011
    Yonkers, NY
    No didn't work.
  8. #21
    Mar 2011
    Virginia
    Great info.
    I tried it by renaming via the phone itself. Didn't work. I'll try by renaming via iTunes and try again
  9. #22
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    I had that issue with my phone when I switched from the 4 to the 4S, I had to go in and totally delete them, then it had that pairing issue, I reset the phone with bluetooth disabled and then re found the phone and it worked just fine.
    Lead Wrench @ WTF Tuning, LLC
  10. #23
    Mar 2011
    Virginia
    Quote Originally Posted by T0rque View Post
    reset as in wiped clean? Or reset as in hard reset home and of button?
  11. #24
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Somebody sort this out quick.I need to buy me a phone.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  12. #25
    Dec 2004
    Medford, Oregon
    reset with home/off button while blue tooth is disabled
  13. #26
    Mar 2011
    Virginia
    Tried this tonight. Turned off bluetooth, oddly enough after the reboot BT was enabled.
    Still not working. I may just do a restore on the iPhone. My iPhone 4 was VZW and my 4S sprint. Has me wondering hardware maybe? I dont know!
  14. #27
    Dec 2004
    Medford, Oregon
    weird, is it version ios 5.0.1?
    Mine works great.. sorry to rub it in
  15. #28
    Mar 2011
    Virginia
    Hahaha you bastard. Here is the version #. I am going to try one more time. Reset everything hard reset my iPhone. And if that doesn't work I may try to see if I can return it for another.
  16. #29
    Sep 2011
    Southern Oregon
    i was having this same problem when i switched from 4 to 4s. I researched around and found that to get it to work right (auto connect) you have to use the steering wheel controls and go through the spoken menus to completely delete your old phone. Then, again using the steering wheel controls, go through the menus to set up a new phone...new name, new passkey and everything. I was originally trying to pair my phone through the menu on the actual head unit and then i was having to manually connect every time i started the car. So make sure you use the bluetooth controls on the steering wheel.
  17. #30
    Mar 2011
    Virginia
    Quote Originally Posted by kyky489 View Post
    Worked!!! There were two stored devices, deleted them this way. Which is odd because they weren't there if I did it on the stereo
    Anyways, thank you!
