Results 1 to 14 of 14
This is a discussion on Has anyone fit 3" deep 6.5" speakers in their doors? within the Electronics/Car Audio forums, part of the Interior Mods category; I want to get started on installing my audio equipment and I was wondering for those of you that have ...
    Registered User Hoofhearted's Avatar
    Aug 2011
    I want to get started on installing my audio equipment and I was wondering for those of you that have bought spacers if you are running mid bass that are 3" deep? These 6.5 Universal Speaker Adapter Ring Set- Subaru 96-09, Saab 92x look to fit up to 2.95". And these Subaru Impreza 08+ Door Speaker Spacers - Interior Accessories don't say how deep but you have the option to go up to a 3/4" ring. Any help from someone that has gone through this already will be greatly appreciated.
    Registered User SamXp's Avatar
    Nov 2010
    Winston-Salem, NC
    Go with the 3/4" and you'll have plenty of room. I'm using these with a 3/4" spacer:
    Dayton Audio RS180-4 7" Reference Woofer 4 Ohm 295-374
    Apr 2007
    8000' up in Colorado
    The problem I've run into is the woofer will hit the inside of the door panel if it has much travel and you don't have a sub to run your bass separately.
    Scott
    Aug 2011
    Quote Originally Posted by SamXp View Post
    Dimensions: A: 7-1/8", B: 5-3/4", C: 3".
    Is the C: 3" the depth measurement?
    Sent from tapatalk.
    2011 Base WRX
    Nov 2010
    Winston-Salem, NC
    Quote Originally Posted by Hoofhearted View Post
    Sent from tapatalk.
    Yes
    Texas, United States
    Yep.. my speakers fit fine depth wise, but with the spacers the cone surround would make contact with the door panel. I ended up taking a utility knife to my door panel and was able to remove just enough material to alleviate the problem.
    Aug 2011
    Millbrae CA.
    Do you have these setup in the back doors? And what are you running them with? Did you take a look at the Kicker 6.5" shallow mounts as well before deciding on the Daytons?
    WRX MY11 SSHB, SPT STS & KB STS,REDLINE BOOTS,KENWOOD KIV-BT901,HAT I61-2 as coaxial FRT, Dayton Audio RS180-4-7 rear, 8" Arc audio subwoofer 2ohm , powered by XDi805 Arc Audio.
    Aug 2011
    Quote Originally Posted by Kankin View Post
    They are going in the front doors. A member from nasioc made me some spacers to the CDT specs for the es-620. They will be powered with a old school kicker zr360.
    Sent from tapatalk.
    2011 Base WRX
    Aug 2011
    2011 Base WRX
    Negative Nancy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Aug 2011
    Millbrae CA.
    Ah ok cool! Sam did you fit the Daytons on the back doors?
    Apr 2007
    Why would you run those in the back doors? Run good speakers in the front doors and filler speakers in the rear. You have less space in the rears so unless you're prepared to chop a hole through your door panel so the woofer can travel enough, it isn't going to work.
    Scott
    Aug 2011
    Or better yet don't run any speakers in the rear.
    Sent from tapatalk.
    2011 Base WRX
    Aug 2011
    Millbrae CA.
    That's why I wanted to run these in the back as a filler for some mid bass and run some better coaxial or components in the front, so I take it that these will be too deep for the back doors even with a spacer?
