Results 1 to 2 of 2
This is a discussion on Amp kit install on 2010 WRX within the Electronics/Car Audio forums, part of the Interior Mods category; I've about searched high and low for this, is there a diagram or how-to for installing an amp kit to ...
    Sep 2011
    I've about searched high and low for this, is there a diagram or how-to for installing an amp kit to a 2010 WRX, non-STI. This is mainly for the LoC as I'm not sure how I can install in based on the 4 speakers and that they're inside the doors.
    Thanks for your help.
    Registered User G8toWRXDave's Avatar
    Sep 2011
    Western NY
    you should install the LOC where you can easily get to all four channels (or however many you choose to run). I would recommend behind the headunit, assuming you are keeping the factoy one. If youre going aftermarket you will not need a LOC as your headunit will have RCA preouts which ran be run directly to the amp. also some amps have high level inputs built in, making an LOC unnecessary. but you still have to tap into the factoy wiring if using an LOC or the amp high level inputs.
    Im new around here, i dont have a wiring diagram readily available.
