Somewhere you hooked the power supply to the switched 12V supply. That line isn't mean to support a lot of current draw, so you need to pull the unit back out and check all connections again.
I assume you used a wiring harness that came with instructions? If so, it should only take a while to go through and check all the colors match.
LinkBack URL
About LinkBacks
