Results 1 to 5 of 5
This is a discussion on Instrument panel lights might have a short. within the Electronics/Car Audio forums, part of the Interior Mods category; So I have a 2004 wrx and my stock gauges are really dim, almost completey out but only on the ...
    Apr 2011
    Missoula montana
    So I have a 2004 wrx and my stock gauges are really dim, almost completey out but only on the right side. My gas and temp gauge work fine. But sometime the temp gauge goes out too so I have to give it a love tap to get it back. Any ideas????
    Jul 2010
    Cincinnati
    burnt out bulbs or a loose connection at the back of the cluster would be the first things I'd look for.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    If you haven't fiddled with anything like the clock or radio, I'd just pull out the cluster, disconnect the harnesses, and try again. If not, pull it again and swap the bulbs and see.
    Apr 2011
    Missoula montana
    How does that cluster come out??? I see some screws above the cluster??
    There are vertical screws facing upwards, don't forget those. Drop the steering column to max low, remove all the screws, and it comes out. There are three harnesses behind it.
