Unfortunately, I've never installed an aftermarket bluetooth mic but I would suggest mounting it onto your steering wheel column? Or perhaps tucking the the wire along the A pillar up onto the sun visor? Keep us posted on your results!
This is a discussion on Aftermarket Bluetooth Mic Location within the Electronics/Car Audio forums, part of the Interior Mods category; Just installed a Pioneer FH-P8000BT stereo in my car. Really easy install! Got a noticeable boost in bass and sound ...
Just installed a Pioneer FH-P8000BT stereo in my car. Really easy install! Got a noticeable boost in bass and sound quality! Still not where I want it to be, but you gotta start somewhere.
I wasn't sure what to do about the bluetooth mic. Any tips on where to place it to get good sound and looks? I had heard that on the dash or rearview mirror have great sound, but I have no idea how to route it to there while hiding the wire.
Any tips?![]()
2011 Subaru Impreza WRX Premium Sedan
2011 WRX DGM Limited Hatch
Stink-Eye Mob #408
Cobb AP Stage 1, AEM CAI, SPT CBE, Tint, Red Tail Overlays, V1 hardwire, RA Mudflaps, STI STS, HT Auto Front Lip
I like the idea of going up the A-pillar but I'm not sure how I would do that and hide the wire...
I have the Pioneer P-9800BT, and I used a small piece of double-sided tape and mounted it right on top of the steering column.
2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
Co-Founder/retired Admin-www.slcsubaru.com
How do you get the wire to come out of the radio slot without looking ridiculous though? I couldn't see any way to route it out the back, and I don't want to remove the whole dash for something small like this.
You can route it out the back and have it come out anywhere you want. The easiest way would probably be to route the wire to the left, then downward to where it comes out above the gas pedal underneath the dash, then route it where you want it to go behind the dash from there.
I routed my V1 hardwire cable this way, and up the A-Pillar next to my rearview; it's not difficult.Originally Posted by MainFrame
I decided to re-use factory location, inside interior light cluster between mirror and sunroof. Works pretty good. Remove driver-side A-pillar cover, bottom half of the driver-side dash, driver-side visor and then light cluster itself. A little disassembly and you can move OEM mic out of the way and utilize some good double-sided foam tape.
"At dawn they sleep..."
Easiest way to get the wire out is to go out the back of the stereo, then across the top of your pedal box (zip tie it to keep it out of the way of your pedal bits) then up the side of the dash to where the A pillar meets the dash. Depending on where you put the mic on the headliner/rearview, tuck the excess wire above the headliner (there is a gap between the windshield glass that about a quarter inch wide)
pioneer mic's work best at the top of the A pillar aimed toward the driver. I used 3m stuff and stuck mine to the windshield in the far upper left corner. I popped the cluster surround out and ran the wire over the top of the cluster and up the A pillar where it pokes out at the top and clips into the mount stickied to the windshield.Works great.
OBP 2010 5dr *traded*
SWP 2013 FRS
SUCH IS MANGO!
Mine is mounted off the headliner near the rear view mirror. Seems to work okay. Ran the wire behind the a-pillar and the headliner.
This is nearly exactly how I did mine. My excess wire is just bundled and wire-tied up under the dash. This is a very easy wire run; be sure to pop off the plastic cover to the left of the fuse box. The pillar trim cover is held on by one screw (under the little square cap that says SRS Airbag) and a few clips. This mic (Kenwood model) has a little metal bracket that I just clipped onto the pillar trim- no glue/tape/sticky goo of any kind. The mic is small enough not to interfere with the visor, and sounds great (so I'm told!)
Here's a pic:![]()
2008 4-Door WRX in Dark Gray Metallic
Greg
www.modmeets.com
ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
Mods Blog Post
Friends don't let friends drive Mitsubishis.
To be honest, I'm note sure I've ever used HF with the window open! I've had this in for 3 weeks or so and right now it's windows closed/ AC weather around here! I'll know for sure in the next month though. The good news is, if I do decide to reroute, there's plenty of wire, and I didn't use any adhesive anywhere other than a few 1" pieces of electrical tape along the wire in the pillar trim. I will report. Maybe I'll do some test calls...
Jer
