Anyone?
This is a discussion on 2008 WRX Premium have sat antenna? within the Electronics/Car Audio forums, part of the Interior Mods category; Ok, I picked up a '08 WRX and was wondering if it already had a sat antenna. I just got ...
Ok, I picked up a '08 WRX and was wondering if it already had a sat antenna. I just got this and the research I did looks like the window has a built in FM antenna, so, if that is the case, what is the antenna above the back window? The car is sat ready, just dosent yet have it. I have an aftermarket unit to put it with sat. but cant figure out best place to mount antenna, so I was hoping it is already there. However, I think the research I found was wrong, but I'm hoping for the best
Anyone?
been awhile, still unsure of this, so a bump to the top for a possible answer...
Yes, my '08 Premium WRX has SAT/NAV. I assume the antenna on the roof is for both functions.
I wasn't aware of any Imprezas before 2011 having an OEM rooftop sat radio antenna. Yours may be aftermarket, or the OEM antenna used on 2011 models. Can you post a picture?
Normally, "sat ready" in a Subaru simply means that you have a stretch of coax antenna cable running from behind the HU to behind the molding above the rear view mirror (to make it easier to install Subaru's antenna, which sticks on the inside of the windshield).
You also have to install the OEM sat radio tuner module -- that is not pre-installed. The OEM sat radio kit includes the tuner module, mounting bracket, antenna, and a harness to connect to an expansion port on the OEM radio.
1996 SVX L AWD. Subaru pin-outs & other handy info
I have the Premium model so it came standard with NAV and SAT radio (requires monthly payments so I just get a weather channel). You should be able to see my pics on my profile...
