03 WRX - Stock Sub with Aftermarket Head Unit Question
Results 1 to 5 of 5
This is a discussion on 03 WRX - Stock Sub with Aftermarket Head Unit Question within the Electronics/Car Audio forums, part of the Interior Mods category; Hey guys, I have a 2003 WRX. I replaced the Head Unit a year or two ago with a Sony ...
    Jun 2009
    Question 03 WRX - Stock Sub with Aftermarket Head Unit Question
    Hey guys,
    I have a 2003 WRX.
    I replaced the Head Unit a year or two ago with a Sony Xplod deck, it has 52W x 4 pre-amp, etc...
    I used a Circuit City plug-n-play harness.
    I also replaced the front door speakers and rear door speakers with Alpine's (front) and Phillips (rear).
    After replacing the head unit and speakers, my stock subwoofer stopped working, so I unplugged it.
    The sound is still pretty good with the speakers but I kind of want to use my stock sub still.
    Any idea why the stock subwoofer stopped working, does it have anything to do with the plug-n-play harness from Circuit City, or the speaker replacement?
    Any info would be greatly appreciated.
    Thanks.
            MainFrame's Avatar
    Austin, TX
    Did it ever work after the install? If not then it's not installed properly. If it quit working shortly after then it's probably no good anymore. I keep telling people, I've had experience with three OEM subs, and all three ended up in the trash.
    For $90-$100 you can get an aftermarket sub that will fit in the same place and sound much much better.
    Registered User FlyWire's Avatar
    Jul 2010
    VA
    you loose your factory sub with aftermarket radios
  5. #4
    Registered User SVXdc's Avatar
    Mar 2005
    Atlanta, GA
    The OEM sub will work with most aftermarket HUs. The subs simply tap off the front or rear speaker outputs.
    A few of the OEM sub models (around 2002) also connect to a 5th-channel output (the HU has an extra 8-pin socket). Sounds like yours is this type. Easy to fix -- you just need to jumper two pairs of wires. See this post in my 'Stock HU info' thread (post #5). Also see post #4 above it.
  6. #5
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    you just have to tap it... I did it myself with my pioneer avic deck and the stock sub woofer.
    It's super easy to do. Took 20 minutes including removal and reinstall time.
    There's a how to on nasioc
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
