Results 1 to 13 of 13
This is a discussion on Changing head unit - Blue wire? within the Electronics/Car Audio forums, part of the Interior Mods category; Hey, i bought a new pioneer headunit to replace my old jvc one. I am only having 1 problem. There ...
    Apr 2010
    Hey, i bought a new pioneer headunit to replace my old jvc one. I am only having 1 problem. There is a blue wire that use to be connected to the JVC head unit. There is no blue wire on the pioneer wiring loom to connect it to. Does anyone know what the blue wire is for? ( The blue wire is not the blue/white remote wire.)
    Apr 2010
    Ok so i found out that its the auto antenna wire. My problem now is the pioneer head unit doesnt have a auto antenna input. It does have a remote wire for a amplifier though. Should i hook it up to that?
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    What model pioneer is it? Maybe we can look up the pin/wiring diagrams to better help you out. Does the car have a power antenna?
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Jan 2005
    Eh, whaaaaa?
    If you don't have a power antenna (one that needs a signal to raise it with a mechanical motor) you don't need to hook that up.
    Cody
    Texas, United States
    Quote Originally Posted by Anub1s View Post
    ^^what he said.. if you're talking about a Subie, we don't have power antennas. I remember working with my brother's power antenna on his Mercades and the whole thing was PITA. We eventually ended up replacing the whole unit with a regular antenna because the damn thing kept jamming..
    Apr 2010
    Im not sure if i have a power antenna. ITs a 04 wrx sti version 9
    Jul 2010
    Wtf is radio? Delete and shave
    Registered User FlyWire's Avatar
    Jul 2010
    VA
    The pioneer has a blue/white wire then correct? If so hook up that to the remote wire which is also blue/white. If you have a blue/white (remote) on the radio's harness and a Blue on the adapter harness connect them together. If your car side harness doesn't have a blue wire at all then you shouldn't need it for the radio to operate, it will operate through the antenna cable (not on the harness) I hope that helps.
    Apr 2010
    Sweet thanks for that. I did what you said and almost everything is working sweet now. Only problem is after hooking my head unit up i noticed that when i turn my car off and take the key out of my ignition my clock, cigerette lighter port (radar detector), window wipers, sterio and amp stay turned on. Im scared this will drain my battery if i leave it for too long. Why is this?
    I was told to join the yellow and red wires together on the head unit then join the yellow and red wires together on the car wiring harness then connect the yellow and red wire from the head unit to yellow and red wire on the car wiring harness. So the yellow and red wires are all connected together as one whole wire. Do you think this may be what is causing everything to stay powered up?
    Apr 2010
    Or maybe its because i didnt split the remote wire. There is a amp wire and an auto antenna wire connected to the remote wire in the same place and the wires arent split apart? They are all joint together?
    Jul 2010
    Cincinnati
    Quote Originally Posted by queenstown3 View Post
    That is why everything is staying on. The yellow wire is a battery wire that is hot all the time, the red wire is from the ignition switch, they need to be separated.
    Does your car have a telescoping motorized antenna? In other words, does your antenna have an electric motor attached to it and automatically retract when your radio is off, and then extend itself when your radio is on?
    AFIK Subaru has never used power antennas in any of their cars.
    Jul 2010
    VA
    ya thats definetly causing the problem, connect yellow to yellow and red to red. Basically just match all the wire colors.
    Just for reference, some cars still require power to the antenna. Not to power a motor but to amplify it. These would be the ones you see in the back windows that look like a defrost element. But that doesn't really apply here, sounds like you have your antenna connection right. Just get those power wires straight, that will definitely drain your battery.
