No, you don't have to switch head units, but a quality aftermarket head unit will always have much better sound quality, especially when hooking up an external amplifier.
If you're dead set on keeping the factory HU all you have to do is tap into your speaker level outputs (front or rear) and run them into a line level converter. Then you can just plug RCAs into the converter and the other end into the amp. Set the gain on the converter and the amp and you're done.
LinkBack URL
About LinkBacks
