If you got a correct harness, it should be pretty well color coordinated. Black to black. You should be good to go. Its a ground wire, so as long as you connect it to a grounding point or another grounding wire, you'll be ok.![]()
This is a discussion on Question on aftermarket head unit within the Electronics/Car Audio forums, part of the Interior Mods category; I hope someone out there can help me on this. I purchased a new head unit today and when installing ...
I hope someone out there can help me on this. I purchased a new head unit today and when installing it, I noticed that the wiring harness I bought had a black wire on it that said "Subaru only." Does that mean I connect the black ground from the head unit to the black wire on the harness? I tried it like this and the head unit worked fine, but I didn't want to solder anything until I know for sure. Thanks!
Thanks for the response. I ended up checking with the manufacturer and they confirmed to connect the black to black since it is a subi. If I would have known how much of a difference it would make, I would have installed the new head unit a long time ago! It has completely transformed the stock speakers for around $230. Well worth it!
We've had a couple recent discussions around here on how H/Us are waaaay underpowered (virtually any car audio system is this way). You did the right thing
Imagine what you could do by even replacing the interior speakers, adding a subwoofer to properly push the lows, and even amping the interior speakers...it can make a world of difference.
