Just keep the volume low for a while. It probably tells you in the alpine manual that came with the sub. Do you have it hooked up to 4ohms or 2ohms?
This is a discussion on New subwoofer how to break in amp power level? within the Electronics/Car Audio forums, part of the Interior Mods category; NOTE- this isnt a thread to argue about if breaking in subs is a myth or fact, its strictly for ...
NOTE- this isnt a thread to argue about if breaking in subs is a myth or fact, its strictly for advice, thank you.
I just installed a 12" alpine type R sub with an Alpine MRP-M500 amp. The subs rated at 500 watts rms, and the amp is rated at 500 watts. Im wondering how to break in the sub, if i should turn down the amp eq level(which is what ive been doing all day, but now that i think about it seems like it could be wrong), or just play the volume low on the stereo? I have no way to adjust the sub level from my crappy Pioneer deck, obviously that would be the easiest way.
Thanks.
2009 Red WRX Sedan
2003 Red Honda VFR
1998 Red(ish) Regal GSX, Stage 3 Supercharged (SOLD)
1991 Red K5 Blazer (SOLD)
the amps 2 ohms, the subs 4 ohms, sounds great...theres a knob on the amp labeled 'sub eq'....im wondering if this adjusts the sub volume level, or the power going from the amp to the sub?
I am going to assume you have the single voice coil sub. So it looks like you are running your system at 4 ohms then, the amp is capable of being wired to a 2 ohm sub. Thats all the 2 ohms mean. So you are looking at putting about 300watts rms to the sub which is a good idea. It is a safer idea. You will not be able to damage the sub as easily and the amp will run cooler. As for power to the sub there should be a "gain" adjustment on the amp. What you are supposed to do is get a tuning cd that puts out a certain frequency, then you adjust the gain on the amp so that the outputs to the sub are a certain voltage.
to do this you will need the Cd and a voltmeter.
My recommendation is just take it easy for the first month or so, keep the gain at a lower level and enjoy it!
2009 Red WRX Sedan
2003 Red Honda VFR
