You arent going to get good sound quality from stock speakers...If you get an upgraded head unit then I would replace the speakers too. Then you'll have to throw in an AMP. Then you'll have to get a sub or two just to make your system complete. If you're going to do a system right the best way to do it is all at once. It's less pulling apart your car. Plus what you're looking for is pretty expensive. You should use that money on a TBE and get some power out of your car instead![]()
LinkBack URL
About LinkBacks
