2009 WRX Premium Wiring Diagram
Results 1 to 3 of 3
This is a discussion on 2009 WRX Premium Wiring Diagram within the Electronics/Car Audio forums, part of the Interior Mods category; Hi everyone, i'm new to the forum thing. I hope i'm posting this in the right place. I'm looking for ...
    Nov 2008
    SoCal
    Question 2009 WRX Premium Wiring Diagram
    I'm looking for the stereo wiring diagram for a 2009 WRX Premium with the 6 disk changer. I'm mainly looking what the pinouts are on the stock harness. Thank you all in advance.
    Registered User Spincycle's Avatar
    Jul 2007
    Janesville, WI
    Here is info and the link to the site that holds the info on NASIOC
    Stock head unit information -- pin-outs, aux inputs, and more - NASIOC
    Starting in 2008, some non-Navi Subaru radios use a new 20-pin connector for speakers and power.
    Close-up of new-style 20-pin power/speaker connector:
    (click for larger image)
    This picture is the connector on the back of a factory radio.
    The connector has two rows of 9 smaller pins, plus two larger pins on the far left and right sides.
    20 pin connector pin out:
    Code:
    1 2 3 4 5 6 7 8 9
    10 20
    11 12 13 14 15 16 17 18 19
    This is Subaru's numbering scheme, looking at the pins side of the car's harness (opposite gender of the above picture) — car's wires pointing away from you.
    Pin Assignments:
    Code:
    Pin Function Car's Color EIA Color
    1 Illumination Violet Orange
    2 Dimmer Black/White Orange/White
    3 +12 Accessory (Ign. Switched) Yellow/Red Red
    4 Steering Wheel Controls – Brown —
    5 Left Rear Speaker – Red/Black Green/Black
    6 Left Rear Speaker + White/Red Green
    7 Left Front Speaker – White/Black White/Black
    8 Left Front Speaker + Blue/Orange White
    9 Antenna Booster Yellow/Black Blue
    10 Ground Black/Blue Black
    11 CAN data bus Lt Green/Red —
    12 CAN data bus Pink —
    13 (NC) — —
    14 Steering Wheel Controls + Yellow —
    15 Right Rear Speaker – Red/White Violet/Black
    16 Right Rear Speaker + Gray/Green Violet
    17 Right Front Speaker – Green Gray/Black
    18 Right Front Speaker + Brown/Yellow Gray
    19 (NC) — —
    20 +12V Battery (Constant-on) Blue/Red Yellow
    Notes:
    EIA is a standard for wire colors used by nearly all aftermarket head units (HUs) and harnesses
    Illumination = +12V when headlights on, otherwise open-circuit
    Dimmer = variable voltage from 12V (dimmest) to 0V (brightest) [yes, backwards — not a typo], same as instrument panel lighting
    The Navi radio has a second harness with nav-function wires. Sorry, I don't have that pin-out info yet.
    Nov 2008
    SoCal
    thanks for your help. my amp is all hooked up. thanks again.
