Building my new system this week. - Page 8
Page 8 of 9 FirstFirst 123456789 LastLast
Results 106 to 120 of 122
This is a discussion on Building my new system this week. within the Electronics/Car Audio forums, part of the Interior Mods category; Thoughts on your voltage test. #1 your car is not running therefore your system is not running at max voltage ...
  1. #106
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Thoughts on your voltage test. #1 your car is not running therefore your system is not running at max voltage in which your system is rated. Your 4V preouts are most likely rated at 13.7V DC system voltage. If you are at 11.3V, no wonder its running low. Will it accommodate for all the loss? That I dunno.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  3. #107
    Jun 2006
    Nor Cal
    I also noticed your tester was on Ac voltage mode, Any difference if you switch it to DC setting since you are dealing with a DC system?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  4. #108
    Nov 2005
    Bay Area, CA
    Quote Originally Posted by 06wrx4me View Post
    you are not dealing with DC on RCA preouts. They are sine waves which are A/C. DC shows nothing.
    2015 Subaru WRX Limited
    2015 Subaru Forester XT Touring
    LastHumansGarage
  5. #109
    Jun 2006
    Nor Cal
    Quote Originally Posted by plac View Post
    Did not know that, thanks.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  6. #110
    Nov 2005
    Bay Area, CA
    np, car cd players use a DAC chip. digital to analog converter. CD output is digital. music cant use a digital signal since it is only "on/off" sort of idea. So it converts it to analog signal before leaving the deck.
    LastHumansGarage
  7. #111
    Jun 2006
    Nor Cal
    cool. You should try re-running your voltage test with the car on.
    What make/model battery are you using, and whats it rated at?
    Are you running any capacitors? AFMKT alternator?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  8. #112
    Nov 2005
    Bay Area, CA
    And.... the huge results I have been waiting for, for the last week.
    My McIntosh amp IS bad. It is not my tweet. My left side (always been my left side) has a cricket snap crackle pop in the tweet almost always. I heard it all last night on the way home. Last night I swapped my amps speaker wires to the opposite passive crossover boxes. My snap crackle pop is now on my right side tweet. I'm now 100% sure its the amp.
    Plans? Well I will send that amp off and spend money to fix it once its out. Its too beautiful cosmetically to get rid of. But I will have my new system up and running by then. I just got a work bonus of a few thou, and I think I will buy another amp. Additionally, I am not thrilled with that Alpine amp, so this would be an all in 1 solution. A 4 channel amp for fronts and sub. One of my top choices is a mint McIntosh 100x4, I just love them. I don't feel a TRU T series would be equal to a McIntosh to my ears. I would love a billet TRU 100x4 but that is WAY too expensive. I would spend $400-$600 for the right amp, depending on how mint it was. This will also cause me to order a new fiberglass bucket for my amp rack, which the company said they can send me. It just bolts on to that MDF carpet piece. I now go to ebay and start looking around. I'd be pissed if I got another broken McIntosh.
    LastHumansGarage
  9. #113
    Nov 2005
    Bay Area, CA
    Current status:
    -McIntosh amp off to repair at McIntosh headquarters in NY. (Amp will be sold once I get it back to offset some costs)
    -JL 10W6v2 sold and gone 2 days ago
    -CDT Classics pulled and for sale
    Current setup:
    -Alpine 9887
    -Alpine MRD-M605 sub amp
    -sub box removed for now
    -ONLY speakers right now = stock rear doors :lol:
    Next stage of plans:
    -A new set of Alpine Type-S coaxials arrive tomorrow, those are to tide me over while I work on a new front component set. The new version of type-s suck, so I had to buy last years version. (88dB vs 92dB sensitivity, more RMS handling not suited to deck power, etc..)
    -The most expensive amp I have ever had arrives tomorrow. There will be pics tomorrow night hopefully. this amp is a 4 channel amp which will run a front stage and a single sub.
    -My ID 10" v3 sub arrives tomorrow. I don't know if this is the "max" or the "q" version, the description doesnt say. But its lower end, handles 400Wrms. I'm hoping to get a bit more output and loudness from it, compared to my W6.
    -New amp rack tub ordered for my new amp, can't have one with extra holes showing. Just the fiberglass part, not the carpet part.
    This weeks upcoming work:
    Remove amp rack from car again. Uninstall Alpine sub amp and prepare for sale. Install new amp on new rack. Install amp rack back in car, wire up. Way for my JL 4 channel RCA's to arrive, they are backordered a couple places currently. My 2 channel JL RCA is killer and I love it. Install my new sub in the Audio Integrations sub box and put back in car. Hook up the sub to one half of my new amp. Run the type-s coaxials off deck power with the amped sub and think about my new component set to order. Strongly aiming to Focal Polyglass as I have heard them, owned them, and I know I love them. It willbe a close fit with a 3/4" spacer, I dont know if they will fit. They are 2.66" depth approximately.
    LastHumansGarage
  10. #114
    May 2007
    Delaware
    I noticed btw your sub box and amp rack, there is a dis-colored spot, is it dirt of is your trunk leaking water? Also is that box designed for that sub? You many have answered this already were did you get it, how much, And does it stick to the corner of the trunk?
    Sorry for all the questions. I def like the setup. still leaves you trunk space. You wanna come to DE, and help me do mine? I'm doing all CROSSFIRE CARAUDIO, other than rear door speakers, but sub, amps, components.
  11. #115
    Nov 2005
    Bay Area, CA
    Quote Originally Posted by Slayer_X View Post
    That is simply a dirty carpet from a car with 61,000 miles on it. I have a new carpet on order. It's dirt or grease, not water.
    The box isnt designed for a particular sub. It has a volume of about .85-.95 cu ft. It bolts to the trunk floor thru and existing hole. No drilling required.
    LastHumansGarage
  12. #116
    May 2007
    Delaware
    Anyhow looks great, love the setup, and placement of the component crossovers as well. Thanks.
  13. #117
    Nov 2005
    Bay Area, CA
    oh, you can get the box here:
    http://www.audiointegrations.net/PerfectFit.html
    LastHumansGarage
  14. #118
    Nov 2005
    Bay Area, CA
    Well, got the final word. McIntosh benched my amp for 5 days straight. Zero issues. They are sending it back.
    LastHumansGarage
  15. #119
    Nov 2005
    Bay Area, CA
    Pioneer PRS 720s
    Got them installed tonight, staying up until 1am. I'll start auditioning tomorrow.. and see if my static issue returns from my previous setup.
    Initial impression, very high end set. The tweets are super heavy and the passive boxes are larger than most sets I have seen. The woofers were immense, and I barely fit them with both my 3/4" custom HDPE spacer as well as about a 1/2" one included in the set. The black spacer that the speaker is sitting on comes with the set, and is optional. The tweet magnet is too stong. I set it on my workbench. It pulled tiny screws INTO the dome thru the grill and crushed it.. Luckily... I carefully pulled the screws out and blew on the dome. It popped back out like new. I can already tell how serious these speakers are. I played only one track for 60 seconds at very quiet night volumes. "All by Myself" Celine Dion. The sub sounds were incredible, I dont even have my sub RCA hooked up right now. I am looking forward to really testing them tomorrow. The piano on that song was so light and airy I couldnt believe it, I havent heard it that natural in a long time.
    LastHumansGarage
  16. #120
    Jun 2006
    Nor Cal
    Very nice. Wanna loan me some money? Wow high end indeed
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
