Quote Originally Posted by longislandwrx
whats the best type of tape for this application, will blue masking tape cut it?
thanks alot, great job on the box
Yeah blue will work good but sometimes it doesn't have enough sticky to hold to all surfaces. The green works good too, little better hold. I don't remember what brand it was but I used some tan/light colored tape (I think PG something) and the fiberglass resin actually started to disolve it. It was a mess to clean up and was all over my part. After you tape use a mold release wax a couple of times and then if you can spray it with PVA. It will form a thin barrier and allow you to pull the fibergalss off eaiser. Good Luck
