Ipod Options.... 06 WRX - Page 3
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 103
This is a discussion on Ipod Options.... 06 WRX within the Electronics/Car Audio forums, part of the Interior Mods category; Originally Posted by BxLoco is it possible that the subaru dealership would put a 06 sti wing on a new ...
  1. #31
    Quote Originally Posted by BxLoco
    is it possible that the subaru dealership would put a 06 sti wing on a new wrx????????
    if you pay for it sure, wrong thread though.
  3. #32
    Registered User DJSHADOW7's Avatar
    Aug 2005
    AZ
    Quote Originally Posted by felo3769
    Probably like a radio station. A bit better that tape, but you may still get some interference from radio stations. as far as instructions, its not that difficult to take it apart. They work on plenty of cars but some are still stupid enough that they cant get it right. The wrx radio is probably one of the easiest to remove though.
    im nervous.... ill prob do it this weekend. Ill keep you guys updated.... as long as i know what wires to splice or w/e then i should be good.....
    ...If you ever need anything please don't hesitate to ask someone else first.
    Blobeye Syndicate numero uno.
  4. #33
    Jan 2005
    Quote Originally Posted by DJSHADOW7
    You'll do fine, just take your time. Looking at the diagram, you just need to tap +12ACC (go to Radio Shack and look for 'vampire' taps, or inline taps... you can't go wrong with those) and ground.
  6. #34
    Aug 2005
    AZ
    Placing an order for the Scosche FM-MOD01 Modulator. Im sure all will go well....
    TOOFAST im going to need to borrow your garage for a little bit
  7. #35
    Registered User TOOFAST88's Avatar
    Oct 2005
    Champaign/Buffalo Grove, IL
    I guess you're incharge of bringing the pizza then
    COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
    Blobeye Syndicate #2
    RYB - 01
    "RALLY ON"
    Quote Originally Posted by StreetSlider
    Hellen Keller's favorite color is Blobeye Syndicate.
  8. #36
    Aug 2005
    AZ
    Quote Originally Posted by TOOFAST88
    5-5-5 deal.
  9. #37
    Nov 2005
    San Francisco
    Actually you shouldnt get any interference from radio stations because when you switch the Modulator on, the cars antenna is disconnected. The sound quality will be good, somewhere between tape and cd.
    If you have any other questions, feel free to ask
  10. #38
    Dec 2005
    NJ
    I really would like to do this to my car, but i know little to nothing about car audio and im afraid i may mess something up. I've never spliced wires and honestly do not know what grounding means . Would a shop be able to do this? Like circut city or best buy if i brought in the instructions to remove the headunit (or if i already had it out)? And how does it sound? Is it comparable to a tape or CD?
    In comparison to stock, a new head unit sounds great. You get clearer sound and much better base. The tricky part is that you need to do your research. =
    The most important thing when getting a head unit is RMS power. When they advertise the head unit, they usual advertise the peak power which is meaning less. The quality of the sound comming out of your stereo is determined by the area under the power curve of your head unit. Cheap head units have a high spike but almost no area under the curve and have a low RMS rating. Better unit don't have the spike and have much more area under the curve.
    My Point: If you get a head unit with more then 22w rms per channel, it should sound great. You can find specs on crutchfield.com.
    Bonus: If you get a head unit with the aux or rca input, you can plug your ipod directly into your head unit and not worry about any problems with FM modulators. Also you get CD quality sound rather then Radio quality.
    - Gone
  11. #39
    Registered User eld4au6's Avatar
    Dec 2005
    Anniston AL
    i think i read somewhere that the factory sub upgrade has AUX plugs?? is this true? im kinda new to this also and it would be great if i could use my ipod im my car
    -05 CGM STiBlobeye Syndicate #4
    -97 Acura SLX totaled 231k
    -95 Toyota Land Cruiser
  12. #40
    Registered User amukaoen's Avatar
    Apr 2004
    Aurora, IL
    Quote Originally Posted by eld4au6
    call the parts department at your local subaru and they should be able to answer for you, then when youn find out the answer tell us here... im pretty sure the answer is no though.
    they call STi's STDs because everyone is getting them.
  13. #41
    Registered User chromatica's Avatar
    Jul 2005
    utah
    ah, I just said the hell with trying to figure it out and bought a new headunit (plus, I already have a sub, 2 amps and upgraded speakers so I might as well, but I still like the way the stock one look, but this headunit was cheap and it has 3 preamps and an auxiliary input which is all that I needed.
    So im just going to get one of these, sicne it chargers the ipod and it has an auxiliary output as well.
    Im going to unmount the cigarette lighter and leave it in the back so that I dont have the charger or anywires sticking out. I might make a custom mount for the ipod too, either something from the cubby that I will ahve now, or somethign that springs out when you open up to access the ashtray.
    i did the same thing a few weeks ago..the sound quality is horrible through the charger's jack so i just had to run a cord to the headphones
  14. #42
    Aug 2005
    AZ
    For those interested, this is the peice i will be installing on my 05 wrx. I have read numerous reviews one from a saab 9-2x owner (same headunit as 05-06 wrx). 24$
    http://www.walmart.com/catalog/produ...uct_id=3661255
    Cheaper then crutchfield.
  15. #43
    Dec 2005
    Anniston AL
    tell us how it works, i am afraid to hack into my new subaru but am willing to do this to my 83 bmw 320is.
  16. #44
    Aug 2005
    AZ
    Yes i am pretty damn afraid to say the least.... but after seeing my headlights baking in the oven i think ill be fine with splicin' a few wires.
  17. #45
    Dec 2005
    Anniston AL
    true that
