What is this black plug for? Stock in-dash 6 disc
Results 1 to 15 of 15
This is a discussion on What is this black plug for? Stock in-dash 6 disc within the Electronics/Car Audio forums, part of the Interior Mods category; This particular unit is from an 05 Saab 9-2x Aero, but it's the same across the Subaru line, right? Does ...
    Jun 2005
    Does anybody know what this is for? It looks like RJ45 at first glance, but it's certainly not! Could this possibly be a :gasp: aux input? That would be pretty sweet.
    Registered User Skreekin's Avatar
    May 2005
    Bellingham, WA
    Maybe its for the amp and subwoofer setup from the factory. Dunno for certain but that would be my guess.
    Mar 2002
    Calmer than you are
    no...its not. the factory sub is connected to the speakers, and the signal then passes through the sub x-over and on to the speakers. an AUX input sure would be nice...but I've no idea. could be auto antenna signal for all I know.
    I linked this thread to scoobymods...maybe someone will be of help.
    go f*** yourself
    Mar 2002
    Calmer than you are
    well, accodring to a reply scoobymods, its an input for an external cd-changer...holy crap all this time there was an AUX input sitting right under our noses????
    can you take a shot of the front of the HU? there's posts on scoobymods referring to a 13 pin DIN connector, but not a 4-pin RJ-type. there's a place that sells adaptors to use the 13-pin connector as a aux input. only problem is that it's always "on"...so it will play over radio or CD or whatever else you got. I think you have to make a "silent" CD to use it right...
    go f*** yourself
    Jun 2005
    Here's the front of the unit. It's the 6-disc in-dash changer that is standard in the 9-2x Aero and optional in the Linear. I think it's the same system that is standard in the WRX and optional in the Impreza, but I'm not exactly sure. Can you link the scooby mods thread?
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    I love Saabarus! That plug is in most newer cars. I'm not sure what it's for, but if it's a four pin, it could be a sub out, (pos, neg, and then +,- speaker outs), or input in which case the speaker out would be a speaker in. The only problem is that then you'd have a mono signal, which is highly unlikely. Now if the unit has a voltage sensor, and can detect signal input, you could use all four pins and have stereo....but then how do you switch the unit on, as now all the pins are used up???
    I vote for sub out. Makes the most sense, but feel free to let me know more as this develops.
    Mar 2002
    Calmer than you are
    Quote Originally Posted by ej20fan
    there's talk of a 13-pin DIN connector on the Forester HU that has need used for AUX input on scoobymods...but no mention of a 4-pin. Your HU is different than mine (I have an 02 WRX so i"m not sure what mine has on the back. I'll probably replace mine with a HU that has an SD card reader eventually.
    just go to scoobymods and search "radio input"
    go f*** yourself
    Jun 2005
    I'm not sure what it's for, but if it's a four pin, it could be a sub out, (pos, neg, and then +,- speaker outs)....I vote for sub out. Makes the most sense, but feel free to let me know more as this develops.
    I really don't think it's a sub out. The sub comes with an adapter to splice it in to the large white pin connector in back, and you have to run a ground. I've looked over the PDF of the instructions to install the sub, and there is no mention of anything other than the harness, ground and FM antenna input. In their technical illustrations on the instructions, the little black plug isn't represented.
    Also, I believe this is actually an 8 pin connection. If you look close at the photo, it looks like there is another row of pins a little above the bottom row.
    May 2004
    Kathleen, GA
    Quote Originally Posted by Guy1138
    Yes, thats the same radio/cd as my 05 WRX wagon.
    Happiness is a belt-fed weapon.
    Mar 2002
    Calmer than you are
    guess they changed them then.
    go f*** yourself
    Registered User SVXdc's Avatar
    Mar 2005
    Atlanta, GA
    If this radio is indeed like what's in other recent-vintage Subarus, then yes, the small, square connector is for a factory subwoofer speaker. The radio has a built-in amplifier, so no external amp is needed. See this thread: Stock head unit information -- pin-outs, aux inputs, and more (read down to post #5)
    On some models this connector includes pins for "satellite switches" (remote-control buttons on the steering wheel), and is also somehow wired into the heat/AC control (pin is labeled "body integrated unit").
    The "old-style" subwoofer that 'blarg' mentioned is the factory under-seat amp/sub unit available for many different models. It comes with a T-harness that connects between the radio and the car's 14-pin speaker/power plug that normally plugs straight into the radio. See post #4 in the thread link above. Oh, and BTW, there is no crossover involved; the 14-wires go straight through from the car to the radio and the sub taps off of the rear speaker outputs from the radio. If you were to unplug the connector from the subwoofer, you'd be back to how it was before adding the sub.
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Great finds. I'm glad to see that at least a few members know how to use the search button.
    Mar 2002
    Calmer than you are
    I've been looking around for a cd-changer adaptor from another auto manufacturer (other GM applications for the most part), but I haven't found ANY that use the conector you find on the 02 WRX. I guess eventually I'll end up getting a different HU and be done with it.
    go f*** yourself
    Jun 2005
    Uh, would that be the search button a different forum? Jeez, frickin kill me for asking a good question, and posting pictures to boot. Smarmy ass.
    Hey SVXdc, thank you very much for the excellent information. Blarg, re-read SVX's post, there is no connector we can get, so an aftermarket HU is our only option for good MP3 input. Kinda disappointing,
    Mar 2002
    Calmer than you are
    yeah i've been searching the forums over the last few days...looks like there's just no way to do it, and Panasonic is not very copperative. I ended up doing a modified cassette adaptor mod. I ran the wire between the vent piece and the dashboard. that way it comes out behind my PDA mount. At least I can't see the wire now.
    go f*** yourself
