Results 1 to 15 of 15
This is a discussion on Way to remove small white scrape from paint? within the Detailing Forum forums, part of the Tech & Modifying & General Repairs category; Well the other weekend someone who for anger issues I'll refuse to name attempted to enter my vehicle with a ...
    Moderator
    Jul 2003
    Maryland
    Well the other weekend someone who for anger issues I'll refuse to name attempted to enter my vehicle with a golf size umbrella. It turns out the wind caught said umbrella and one of the ends touched the passenger side rear window. At first the only thing I could think of was the scracthes that I'd see next time I washed the car, but after a quick look I didnt see anything.
    It has been raining ever since then (stupid MD weather) but today the sun came out for 30 mins. So I go and look for any further damage. I find a small scratch on the passenger side front door, under the door handle. After thinking of the point of impact from the umbrella to the pass. rear window, I highly doubt that the umbrella caused this mark due to it's location.
    However I do want to get the mark off of the paint if possible. I took my finger to the mark and gentle rubbed it. It appeared most of it rubbed off. What would be your next suggestion? Do you think some wax might buff it out after a wash? Or should I just wait another month until I polish the car? The car did have a recent coat of wax on it (under a week old) so I know the scrape is recent. It didnt appear to be below the paint or anything as I couldnt feel anything but smoothness when I ran my finger over it. Will this be a scratch that will always be there or does anyone have any secerts at removing them. Thanks
    Registered User DeBlas66's Avatar
    Apr 2006
    Westchester, NY
    Quote Originally Posted by 302@12psi
    If you can't feel it, I would suggest a wash and wax with some elbow grease and that thing should buff right out.
    Car-less
    Jul 2005
    Sand paper. 16 grit.
    Quote Originally Posted by mike05STi
    I'd love to have a tree house for adults in my backyard.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by TacticalNuke
    Your kidding....I hope
    Registered User dcpatters's Avatar
    Sep 2004
    Irvine, CA
    Mother's Scratch Remover will do the trick or Mequiars. Both are amazing. Afterwards, apply a coat of wax.
    2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Quote Originally Posted by dcpatters
    I have used the Mother's. Good stuff.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Jul 2005
    You didn't try it... I hope.
    Apr 2004
    Southeastern PA
    Mods & Pics
    Moderator
    Jul 2003
    Maryland
    I now have a 4x6 inch clear down to the metal surface area thanks to that post....from now on before doing anything on this board I will double check with nasioc. Does anyone think he is legally liabile for passing on bad info?
    And for anyone who thinks I am serious.....I havent lost my common sense yet...
    Jul 2005
    Now for the next step, matching your car's paint with a can from Lowe's and using a roller-sponge to apply it...
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Try getting it out with wax by hand. If you can't, try 3m rubbing compound by hand, and re-wax the area when finished.
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    yeah i doubt wax will do it----its not abrasive.
    compound or polish. try megs scratch-x. dont forget to wax the area afterwards.
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    +1... if id doesnt work add a soak a towell with brake fluid and leave it overnight.
    Registered User ScreamnRex's Avatar
    Feb 2004
    Greenville/Thomasville, NC
    For stuff like that, Meguiars Scratch-X always worked good for me.....give that a shot.
    -03 WR Blue WRX - -Cobb Stage 2 w/Uppipe and Intake-
    Scratches
    I use SafeCut by The Wax Shop. It is marketed as a Swirl and Haze remover but does wonders on small scratches, blemishes.
