STI- engine washable?
Results 1 to 15 of 19
This is a discussion on STI- engine washable? within the Detailing Forum forums, part of the Tech & Modifying & General Repairs category; can you spray the engine with water when your cleaning the car? or is this bad for electronics/parts etc? because ...
    May 2013
    Canberra, Australia
    can you spray the engine with water when your cleaning the car? or is this bad for electronics/parts etc? because its getting a bit dirty but just scared to smash water on it.
    when love of power... overcomes the power of STi, the world will see peace
            MainFrame's Avatar
    Austin, TX
    it'll be fine, just don't get water in the intake.. and I would avoid hitting electronics with a pressure washer
    May 2013
    Canberra, Australia
    intake?
    and would that cause major probs?
    thanks
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by gorecki-STI View Post
    intake?
    hydro lock.. blow your engine.. other than that, you'll be fine.
    May 2013
    Canberra, Australia
    lol how else can I go about cleaning it? its my first car ;P
            MainFrame's Avatar
    Austin, TX
    Squirt it with some degreaser where it needs it, and spray with water. Don't spray water INTO your intake, and if you have an exposed air filter, cover it with a plastic bag. You'll be fine.
    If you're particularly worried, let it sit over night to dry off after washing.
    May 2013
    Canberra, Australia
    sweet, will do.
    heres a pic of the engine...in case there's anything else I should do before cleaning =]
            MainFrame's Avatar
    Austin, TX
    Remarkably stock looking.. I see some aftermarket stereo wiring (inline fuse) you might avoid spraying directly with water, but you don't appear to have much too worry about there. I wouldn't even really worry about getting water in the stock intake, unless you intentionally spray it directly into the snorkel it's not going to make it's way to the engine.
    Nice looking car.
    May 2010
    Pittsburgh, PA
    Agreed with mainframe. If you dig around, sasquatch did a nice write up on it. He recommended simple green as a degreaser, I believe.
    Sent from my Galaxy Nexus using Tapatalk 4 Beta
    2011 STi Build Log
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Here is Sasquatch's write up. How to safely clean an engine bay
    I have used Scrubbing Bubbles toilet and bath cleaner and just got a good layer of foam on the whole engine, let soak then rinse. I have used Simple Green biodegradable degreaser/solvent and also used Purple Powers with the same technique, and I have used the High pressure hose at the car wash with soap and then rinsed with water letting it spray without the trigger pulled (so the pressure/volume is low).
    In my experience (which is admittedly only a little under 3 years with this car) Even if you shot a hose straight up the snorkel I doubt it would do much to the filter. If the snorkus is still there then most of the water will be trapped there and drain out unless you kept filling the intake. The rest might get the filter wet but the intake is designed to do a pretty good job of removing water before the filter. With the snorkus gone the water will simply go into the wheel well and drain out there.
    Jan 2009
    Md
    Just make sure it's off and leave it off. The SG or another all purpose cleaner will work fine. I'd get a toothbrush and a mf towel and just wipe it down, that way the engine has less risk of parts getting wet that might be an issue. The best thing to do is keep the hood up and just let it dry for a few hours. You could also get a box fan and let it blow on it for a few hours as well. No problems.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    The best engine wash I have ever done was with my 03 Sentra Spec V.
    -Spray a whole can of engine degreaser throughout your engine bay. Let that sit for 5-10 minutes.
    -Hose off the engine degreaser, thoroughly, but carefully.
    -Spray a can of tire shine throughout your engine bay.
    -Wipe EVERYTHING
    This made my engine bay look new for a very long time. I let everything for a couple hours, before starting the car, just to be on the safe side.
    May 2013
    Canberra, Australia
    Nice looking car.
    yeah thatd be right lol the car came with a dodgy ass sound system put in, which I got set up properly yesterday thanks for the info!
    May 2013
    Canberra, Australia
    Quote Originally Posted by ProZach626 View Post
    -Wipe EVERYTHING
    Awesome, will give it a go do u recommend any type of degreaser and tire shine? also any differences in driving performance/sound/anything after the clean?
    May 2013
    Canberra, Australia
    Quote Originally Posted by SKI.WRX View Post
    really? scrubbing bubles toilet/bath cleaner work well? and was that a replacement for the degreaser?
    great idea with the hose without pulling the trigger, because even my normal hose at home is too rough I reckon.
    so you would recommend simple green or purple powers? I don't care about price
    thanks for the good info brotha!
