How to safely clean an engine bay - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 78
This is a discussion on How to safely clean an engine bay within the Detailing Forum forums, part of the Tech & Modifying & General Repairs category; let us know how it works out!...
    Apr 2010
    Sacramento
    Apr 2004
    Southeastern PA
    Original formula Simple Green oxidizes aluminum. You need to use the "Motorsports Forumla" Simple Green.
    http://www.simplegreen.com/products_extreme_motor.php
    Quote Originally Posted by Sasquatch View Post
    I have never had any oxidation / corrosion that I could see with original formula Simple Green on aluminum. I've always wet down the cold engine first, then use SG without letting it dry, followed by a thorough rinse. I'd imagine if you let it dry without a good rinse that could cause some issues.
    I'll give the motorsports version a try.
    I just did a cleaning of the engine bay today with original Simple Green. While I do want to try the motorsports formula, I stand by my assertion the original is OK to use provided you do the following:
    • Use on a cold engine only.
    • Begin by hosing down bay with water.
    • Do not allow SG to evaporate.
    • Thoroughly rinse all traces of SG until there is not a single detergent bubble to be seen. Then rinse a little more to be sure.
    There is no information regarding potential aluminum oxidation on the bottle I have or on their website.
    http://www.simplegreen.com/products_...se_cleaner.php
    http://www.simplegreen.com/solutions...=18&artlang=en
    ^^ This link suggests hot water. I've never had access to it in a hose and have always done fine without it.
    My 6.5 year old aluminum OEM TMIC looks nearly new. It will be replaced soon with a Process West TMIC. I'll be sure and have a very close look for any signs of oxidation. I will post the results either way.
    There is also ~ 20 years of experience using the original SG. I do not ever recall seeing any defect on aluminum parts with the four cars I've done this with.
    Mods & Pics
    Apr 2004
    Southeastern PA
    Rewind to 7/2/03
    I totally forgot about these images ...
    This is the engine bay I had then - a 2000 Honda Prelude. Once again, TheJ would be proud to eat off of it. Zero aluminum oxidation - repeatedly cleaned with original Simple Green.
    Mods & Pics
  6. #19
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    you put a VTEC in your Subaru?!?!?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  7. #20
    Apr 2004
    Southeastern PA
    I really loved that car. Way more refined than the WRX, the OEM handling was superb. Long hood, short rear deck. I still pleasantly sigh when I see one.
    Two problems arose:
    • I was too large to reasonably fit into it. A bumpy road would suddenly introduce my skull with the headliner.
    • It drank oil at the rate of 1 quart every 1000 miles. The dealer made TWO attempts to fix this. After which it gulped a quart in about 400 miles. And spewed droplets of oil rich exhaust residue all over the rear of the car.
    I traded this problem car in for the WRX I now love. Zero oil consumption at nearly 54k miles.
    Mods & Pics
  8. #21
    Nov 2006
    Denver Metro Area
    I honestly love the looks of the prelude. If she had a turbo, and RWD... I would've owned one.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  9. #22
    Apr 2004
    Southeastern PA
    Like I said ... I still pleasantly sigh when I see one. Absolutely gorgeous.
    I traded that asphalt spray gun to the dealer I bought the WRX from. To this day I wonder what happened to that poor Prelude I fell in love with.
    Mods & Pics
  10. #23
    Nov 2006
    Denver Metro Area
    I just have never understood why honda made such a great looking car FWD and with such a pig of an engine.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  11. #24
    Apr 2004
    Southeastern PA
    Pig?
    Aside from it being a torqueless wonder I thought it was most entertaining once it hopped onto the VTEC cam lobes. Pre VTEC was an exercise in patience waiting for some forward momentum.
    The intake was a terrific noise maker. It really sounded great and was quite loud in the higher RPMs. I completely understand why WRX n00bs always ask about intakes.
    Mods & Pics
  12. #25
    Nov 2006
    Denver Metro Area
    160whp isn't exactly much of an engine... that car looked like a sports car. it should have performed like one too.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  13. #26
    Apr 2004
    Southeastern PA
    At the time of the 5th generation Prelude intro (1997) 160 was a lot of horse pressure. My stock 2000 Prelude (ironically OEM shod with RE92s) handled a lot better than the new 2004 WRX with the same crappy tires. The HP was bumped up to 200 after the into. Not sure of what year that was.
    The 2004 WRX I bought required stiffer springs, fatter sway bars, a performance alignment, and sticker rubber to outdo the bone stock Prelude.
    Mods & Pics
  14. #27
    Registered User baru-by-u's Avatar
    Mar 2009
    Out and about
    i traded my GAylude for my new subie for the same reason . I got so bad i had to stop a few miles away to wipe it off before selling it
  15. #28
    Apr 2004
    Southeastern PA
    Quote Originally Posted by baru-by-u View Post
    You had a spray gun as well? I've seen a few other minor cases, but nothing like the one I had. The dealer "fix" is what made it so bad.
    Mods & Pics
  16. #29
    Registered User Cam198's Avatar
    Jun 2011
    Illinois
    I got a question: Will regular cleaning of the engine and stuff, help keep down on rust? I live in the Chicagoland area of Illinois, and they use alot of salt on the roads so rust on cars seems to be a big issue around these parts. I don't have a WRX yet, but I figured I might as well ask, so I am prepared for maintenance and what-not, when I get one
  17. #30
    Apr 2004
    Southeastern PA
    Quote Originally Posted by Cam198 View Post
    Removing salt will cut down on rust, so yes I think it would help. We see a good amount of road salt in SE PA. This past winter was one of many nuisance snowfalls - just enough for the salt crews to do their thing.
    Mods & Pics
