Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Best wax for constant outdoors within the Detailing Forum forums, part of the Tech & Modifying & General Repairs category; Originally Posted by LIV 2 RLY I buy all of my detailing stuff from Chris, and I picked up some ...
    Dec 2006
    Central Jersey
    Quote Originally Posted by LIV 2 RLY View Post
    I buy all of my detailing stuff from Chris, and I picked up some Collinite Insulator Wax for the winter. I washed my car for the first time in almost 2 months yesterday and the water was still beading off. The Collinite goes on very easy and is extremely easy to buff out.
    Knew you'd like it That stuff is great.
    Quote Originally Posted by jshillin View Post
    Yep, Collinite stands up to the elements nicely and is easy to work with. Just be sure that you shake it up very, very well. Shake it until it is very thin before you use it, apply very thin coats and it will wipe off easily! If you put it on real thick it will be a major PITA to remove.
    Another trick to the 845iw is to warm it up. In cold weather, you can stick it in a pot of warm (not boiling!!), water, or, on warmer days, just let it sit in the sun. It should more on the liquid/runny side in terms of consistency. Makes it much easier to dispense and work with
  2. #17
    Registered User jshillin's Avatar
    Oct 2007
    Waynesboro, PA
    Quote Originally Posted by Chris(NJ) View Post
    Yep, I've used both methods get it to the proper consistency!!
  3. #18
    Registered User RedHonda00's Avatar
    Oct 2007
    Ohio
    i use collinite also, works well
    A Little Piece of Heaven-Avenged Sevenfold
