Results 1 to 15 of 19
This is a discussion on Perrin within the Dealership, Vendor, and Installer Review forums, part of the ClubWRX.net Marketplace category; What should I NOT buy from them?...
    Registered User iLOVEcone's Avatar
    Mar 2010
    Fort Hood
    Perrin
    Registered User Crb03's Avatar
    Jan 2008
    southern cali
    Stay away from his drugs, chris laces them with something funky.
    "M3 drivers have no friends..." - Jeremy Clarkson
    "If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
    Dec 2003
    Dallas, TX / Sterling, VA
    I know their end links and filters aren't something you'd want.
    Perrin Performance (merged thread) - NASIOC
    ^ Review thread. It will tell you what everyone thinks of their parts. Not the most flattering reviews. They are ok, but definitely not great.
    Moderator Donkey's Avatar
    Da boonies
    Their catch can is the suck. Had the old style inlet and is was "ok". Their header and exhaust is probably the best products they make.
    2002 FORESTER S
    1998 FORESTER S
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Their master brake cylinder stiffie is good...
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Registered User economatic's Avatar
    May 2009
    Portland, OR
    I have their CAI, sways, endlinks, and AP stage 1 maps.
    -The foam filter for the CAI is pretty bad. You can see right through it but there are plenty of other cone filter replacements on the market
    -I had the sways and endlinks installed by a reputable Subaru shop and they said these were quality parts, although the endlinks are more of a racing design so they will make some noise.
    -I haven't blown my motor from their AP maps so no complaints there.
    Registered User Dark WRX's Avatar
    Mar 2010
    43.60081, -116.202681
    I have Perrin up, down, exhaust, recirculating bov, CAI, and wastegate. Tuned on stage 2. No problems whatsoever and have had this setup for a while. Planning to use their stealth black fmic for next step in upgrade. Will let you know if any problems ensue.
    Feb 2009
    Los Angeles
    Great, Quality Product!!
    I've been using their Stage1 Map for 15K miles and no issues!
    Mar 2010
    Edit for me. I have the complete recirc, and the inside needle valve has loosened a couple times. Causing a compression surge or something. So most likely will be going back to stock. Other than that, love the rest of the products I have purchased. Have a wastegate, but I haven't installed yet. Wanna wait to get the green, and the FMIC.
    Hawkeye Alliance#208
    "Time to stab out" - Andy Clair
    Dec 2006
    Philly/DE area
    I know this is a dumb question, but the Perrin recirculating BOV is silent, right? (like the stock BPV)
    It doesn't have to be tuned for either? (because it acts the same as a BPV)
    Mar 2010
    Quote Originally Posted by Pavia View Post
    There's an adjustable cap that you can either have a harder or softer release. The harder is more like the BPV sound. Doesn't make an air sound until the shift. The softer setting is more of a hissing noise during all turbo play. Somewhere in the middle is the ricer noise. I prefer to have as little noise as possible so i have it set to a harder setting.
    Mt. Laurel, NJ
    Perrin Endlinks:
    Build quality is good...but the mounting bolts and hardware blows. Torques to spec when I installed them and my rear sway on my 07STI...about a month later, the mounting bolts shot out of both sides. I hadn't noticed that the endlinks weren't connected until I had to get a tire repaired. I hadn't done much spirited driving, so I didn't notice the body roll. I had to fab up some bolt action with lock nuts and washers from Home Depot to repair.
    Also the sway bar Stout Mounts are garbage. Soft ass Aluminum that stripped inside the bolt holes...after a month after installing them, I shot out a couple bolts and the sway detached from the frame at the mounts...BOTH OF THEM!!!
    I will not be going back to Perrin for suspension mods. Cobb, Cusco, or Whiteline for me in that regard.
    Mar 2010
    ^ I've heard nothing but good things about Cusco and Whiteline. Will most likely go that way with my suspension.
    Dec 2006
    Philly/DE area
    Quote Originally Posted by Dark WRX View Post
    This unit avoids all the pitfalls of the a vent-to-atmosphere BOVs, as used on a WRX? (ie, messing up the metered A/F ratio inputs)
    May 2009
    Portland, OR
    I have to revise my review of their endlinks...I broke one. The top of the link at the pivot broke right off. No clue how it happened since I haven't driven the car agressively.
