Turbo cars simply do not suffer as badly as compaired to NA and superchargers. Even if you have it set to 15PSI, the turbo may have to spin what is normally 20PSI to pump it in. But then you have more heat and less 02 but it is NOT as bad as One may think but certainly a factor. I know there is less 02 and certainly slower spoolup and faster heat soak. You set a wastgate to 15PSI, at sea level and at 5380feet you will get 15PSI albeit with less 02. All other cars will be less, I know Colorado is the land of the 13 second Z06Seriously...do you know what PSIA stands for? As in "absolute"? As in the pressure used within your manifold to manage boost? Might want to read up on the effects of altitude here. Not trying to ping on ya or anything, but two car's with the same setup will NOT hit the same boost pressure at different altitudes. It all has to do with your AFR's. Less absolute pressure to start with means you will have to target a higher boost to get the same performance level, which means different maps all together.
LinkBack URL
About LinkBacks
sorry, you guys are dreaming. If he truely does, then he will trap at 113-114MPH, I doubt he will break ten.
