But I bet you'd chime in when someone pronounces it "Nuke-uler"...
It's been 10+ years since my Physics classes at Illinois, so I'm sure I've forgotten a bunch of principles. I'm just going by what seems to make sense to me. I'm rather hoping someone with an engineering background (or better yet a drivetrain engineer) could chime in with an educated response.
I found a good example that might prove my theory that the percentage stays the same and that driveline loss is not a constant fixed amount. It will increase as HP increases...
A stock WRX and a Stock 2.5RS have essentially the same driveline components, right? Same wheels, trans, etc... I believe the clutch might be a bit different, but not sure if it would contribute much if anything.
Subaru rates the 2.5RS at 165 HP and 166 TQ at the flywheel.
A dyno of a stock 2.5RS shows that it puts out 122.5 WHP and 133.3 WTQ
Dyno results here:
http://www.cobbtuning.com/impreza/im...rformance.html
165 hp - 122.5 whp gives a loss of 42.5 HP. 42.5 divided by 165 =
25.8% loss for HP
166 tq - 133.3 wtq gives a loss of 32.7 TQ. 32.7 divided by 166 =
19.7% loss for TQ
Subaru rates the WRX at 227 HP and 217 TQ at the flywheel.
A Dyno of a stock WRX shows that it puts out 169.9 WHP and 174.3 WTQ
Dyno results here (note, done on the same shop and dyno as the above example, so it should be relatively consistent) :
http://cobbtuning.com/wrx/images%5Cae-stage2-dyno.jpg
227 hp - 169.9 whp gives a loss of 57.1 hp. 57.1 hp divided by 227 =
25.2% loss for HP
217 tq - 174.3 wtq gives a loss of 42.7 tq. 42.7 divided by 217 =
19.7% loss for TQ.
Note how both the HP and TQ losses are higher on the more powerful WRX despite the nearly identical drivetrain. Yet, when the math is done to calculate the percentage lost through the drivetrain, they are nearly identical. Way to close to be a coincidence...
Thus I'd have to conclude that drivetrain loss will stay at or around 25% for a WRX, regardless of power levels. Of course, this may change as people upgrade or change components to handle the higher power levels.
Class dismissed!
