I may start modding my 2nd car
Results 1 to 9 of 9
This is a discussion on I may start modding my 2nd car within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; http://www.is300.net/forum/viewtopic.php?t=13313691 keep in mind those #'s are with an Auto IS300, I have the 5spd MT...
    Registered User All8up's Avatar
    Jan 2002
    Ashburn VA
    e46 M3 (new toy)
    02 wrx w/257 swap (now sold)
    IS 300 5spd w/ NAV (hers)
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Wow!
    The Stage 1 kit (275+ RWHP - Auto Tranny) consists of the following components:
    · customer installable
    · US$3,995.00 +S/H
    · Ceramic base painted, oven baked, tig welded, thick wall, tube-style turbo manifold
    · 7 PSI Max developed boost
    · Turbonetics® T04E turbo unit made to SRT specifications
    · Turbonetics® Turbo heat shield
    · Turbonetics® Racegate in closed looped form
    · Turbonetics® open air blow-off valve
    · SRT Custom double layer fiberglass filled exhaust manifold heatshield
    · Mandrel bent, T304 2.5" stainless steel downpipe
    · (6) RC Engineering 440cc fuel injectors
    · (6) NGK Colder Platinum Spark Plugs
    · SRT air/fuel ECU
    · SRT wastegate pressure regulator
    · Ceramic base painted and oven baked complete mandrel bent hard pipes (turbo-to-throttle body)
    · Mandrel bent intake hard pipe (includes cold air intake pipe as standard equipment)
    · Stainless steel braided turbo oil supply line
    · Stainless steel braided turbo oil return line
    · Silicone hose connectors
    · Silicone vacuum hoses
    The Stage 2 kit (300+ RWHP - Auto Tranny) includes all of stage 1 components and the following:
    · US$4,995.00 +S/H
    · Front mount Spearco core intercooler w/SRT endcaps
    · Hard pipes to and from the Intercooler
    · More aggresively tuned SRT ECU
    · 8 PSI Max developed Boost
    The Stage 3 kit (340+ RWHP - Auto Tranny) includes all of stages 1 and 2 components and the following:
    · customer installable with extensive knowledge of turbo systems
    · US$5,995.00 +S/H
    · Intank 255lph fuel pump
    · Fuel return line with variable rate fuel pressure riser
    · 10 PSI Max developed boost
    · Retuned SRT ECU
    The Stage 4 kit (425+ RWHP - Auto Tranny) includes all of Stages 1 ~ 3 components and the following:
    · US$11,995 +Tax, +S/H, +Shop Supplies
    · MLS 3mm Head Gasket
    · Auto Tranny Valve Body Upgrade
    · ARP Head Studs
    · 550cc Injectors
    · Bigger T04E Turbo
    · Bigger Intercooler
    · Includes Installation and tuning at SRT facilities
    The Stage 5 kit (500+ RWHP - Auto Tranny) includes all of Stage 1 ~ 3 components and the following:
    · US$19,995 +Tax, +S/H, +Shop Supplies
    · brand new 2JZ-GTE short block
    · ARP Head Studs
    · 660cc Injectors
    · Bigger fuel lines and additional inline fuel pump
    · Bigger T04E Turbo
    That's a lot of money to get the numbers, but the fact that it's possible is awesome
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
    Jan 2002
    Ashburn VA
    There is a guy that lives around my way that is essentially a stage 2-3 car. He runs high 12s at the track with a full interior and on pump gas! They dyno'd his car at over 375rwhp (5speed MT).
    IS300 = NA supra w/4 doors and minus 300lbs or so
    e46 M3 (new toy)
    Registered User Flyboy's Avatar
    Mar 2002
    9200' Golden, CO
    Looks like we're going to have to watch out for the IS's!
    2011 SWP Premium Hatchback
    Flapatax Mud Flaps
    Kartboy STS with front and rear bushings
    Cobb AP Stage 1 (for now)
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Just saw an Auto trans-equipped '01 IS300 with an intercooled Area 51 supercharger kit running 15.20's here in Honolulu. I would guesstimate that at 14.70's anywhere else...
    My bone stock IS300 could only muster a 15.90 here once and 16.0's (15.40-15.50's on the mainland) the rest of the time...
    5m's must be way quicker!
    Note: Area 51 IS300 does have 19" bling-bling wheels... That probably affects his performance as well.
    Does the Stage 2-3 kit IS300 in your area run a turbo or blower?
    Jan 2002
    Ashburn VA
    The IS in my area is equiped w/ a T3/T4.
    Also worth mentioning is that 5speed MT's put down anywhere between the upper 180's (low side) all the way to mid 190's.
    The AT equiped IS's put down anywhere between mid 160's to 170.
    When I test drove the AT IS, I quickly thought that I would purchase the Type S. Later that week a 5speed came in and it totally changed the car.
    The few people I know w/ 5speeds muster anywhere between low 15's to upper 14's in the 1320. The guy that now runs 12's, baselined his car at 14.8 last summer.
    e46 M3 (new toy)
    Jun 2002
    Honolulu, HI
    Wow... 14.80's stock? AWESOME! T3/t4 hybrid? Just plain nuts!
    I say go for it! I was afraid to throw any mods on my Lexus - because I mean... Well, it was a Lexus. :-) (and I couldn't afford to fix it if it broke! :-) but if you've got the means... That would be amazing!
    Keep us posted...
    Aloha,
    Richard...
    P.S. I think one of the most awesome "cruise missiles" I've ever seen was that SC300TT whose banzai-highway-run-videos are circulating around the internet. That car was 2jz-6speed-big turbo equipped and reeled in everything in sight! *wow*
    Mar 2002
    Tokyo, Japan
    Thumbs up
    Nice IS300! I like those numbers, plus i like the car itself. Keep us posted with some pictures also
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    str
    str is offline
    Jun 2002
    DE
    5 speeds are pretty quick stock, however I test drove one and compaired performance wise to the WRX and GTI 1.8 Turbo I was not impressed. Nice interior and a smooth ride but overpriced by about $5000 in my opinion.
    2004 Black Forester XT
