Page 4 of 4 FirstFirst 1234
Results 46 to 50 of 50
This is a discussion on T3/t4 Srt-4.... within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I run mine knock free with 100 octane at 26 psi on the base stage 2 map with injector scaling ...
  1. #46
    Feb 2004
    Hickory, NC
    I run mine knock free with 100 octane at 26 psi on the base stage 2 map with injector scaling set to 600cc on stock tmic. So I'm sure 28-30 psi is possible.
    Mods
    Armed with a rotated Precision 6265 turbo at 35psi and a built 2.5 liter.
  2. #47
    Jan 2002
    In the slow lane
    26PSI??????
    Shheeesh! And I get nervous when the boost needle hits 19psi on my boost guage with my 1820 during a highway pissing session
    guess I need to grow some balls and get used to the fact that it is okay to run so much boost
    02 WRX WRBP sedan..
    Upgrades??? stock...
  3. #48
    Feb 2004
    Hickory, NC
    I think a benefit of the new 1820 is the massive power you can get at low boost. The 18g on the other hand, doesnt really wake up till 20-22 psi.
    Mods
  4. #49
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Yup. The newer version 1820's make gobs of power on low boost! I made 310whp/296wft-lbs at 19psi on my 1820. It was a great turbo and felt like it hit harder than my xs450 (it was definitely slower though). As you can see from 13src's car, at 20-21 psi the 18g is just starting to wake up and then from there it can keep going. My turbo acts the same way, just on a slightly larger scale I guess....
    For the boost-phobic among us, the 1820 is probably the best turbo you can get. But if you're willing to run more boost, it can leave you wanting more.....
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  5. #50
    Registered User 13secwrx's Avatar
    Apr 2003
    Midknight is absolutely right. My 21 psi map is run pretty aggressive but my 25 psi map is very conservitive. I'm pretty sure I could on some good solid 100 octane make 350-370 whp right now at that same boost level w/an agressive tune. Its got alot of potential and your 20 g has even more...
    L.I.S.C #00 (Treasurer)
    02 Wrx...465whp and 472 whtq. 100 Octane
    387whp and 371 whtq. 93 Octane
