Me Vs. M3 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Me Vs. M3 within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; You make power in 2 places, 2, one is the aspiration, such as NA, Turbo, N20. 2nd is the head, ...
    Registered User Evilevo8's Avatar
    Aug 2003
    NJ
    2nd is the head, and how well, much, efficient it flows. Donít forget, an engine is only an Air Pump, thatís it, and has been for over 100 years, only the technology has changed.
    The Evo head is AMAZING, AMAZING, it'll flow enough air for the 9's and people are in the 10's on it. The only restriction is the cams, which do not allow too much flow up top, but certainly enough.
    I trapped @ 108MPH with stock cams, stock cam duration is 254 or like that, I bumped BOTH to 272, this allows a LOT more air flow, also aids against detonation, as the exhaust has more time to let out the hot gases. If you had an EGT probe and measured the Temp before and after, it would drop after a cam install with ALL being equal otherwise. So I bumped the Timing and raised the limit to 8000 RPMS, The dyno read like 344WHP, its sick now, and pulls till you hit fuel cut.
    My next mods are simple, (besides some IC piping, I seen the stockers on the dyno, they expand quite a Bit)
    A clutch to hold the power properly
    and a AEM EMS
    That I would take over a new turbo, remember Tuning is KEY, **** everything else, I watched a Stock Turbo WRX run back to back to back 12.8's with nothing more then Boltonís and tuning and a NX N-Tercooler.
    After that then I will **** around with the 50 trims, then it is all over gentleman
    Big 16G=550CFM
    18G=600CFM and a "LIL" more hot
    50 Trims=7-800CFM's and counting
    Don't believe the life you have
    Will be the only one
    You have to let your body sleep
    To let your soul live on
    2006 Evo IX MR
    Registered User 13secwrx's Avatar
    Apr 2003
    The evo comes w/ a reg. 16g I thought . NOt a "big" g...? am I wrong
    L.I.S.C #00 (Treasurer)
    02 Wrx...465whp and 472 whtq. 100 Octane
    387whp and 371 whtq. 93 Octane
    Aug 2003
    NJ
    BIG 16G, beenlike that for a while.....
    The TME has a slightly larger turbo, but not that much, I think it is just more efficient so it can flow teh same boost levels @ lower temps.
    Small 16G will net you 505CFM's
    Big 16G will Net you 550CFM's
    18G will net you 600CFM's but the efficiency is taxed slightly
    20G is like 650-700CFM's
    I am looking for a BB turbo that'll flow 750-800
    2006 Evo IX MR
  6. #19
    Feb 2004
    Hickory, NC
    I forsee a garret going into the evo.
    Mods
    Armed with a rotated Precision 6265 turbo at 35psi and a built 2.5 liter.
  7. #20
    Jun 2004
    NYC...too close to newark:(
    Originally posted by Evilevo8
    I am looking for a BB turbo that'll flow 750-800 [/B]
    HKS 3037
  8. #21
    Aug 2003
    NJ
    **** HKS, great Quality, but WAYYYYYY too Much money.
    Gona go with the AMS kit, LOOKYYYYY!!!!
    http://www.automotosports.com/evo_gt_kit.asp
    2006 Evo IX MR
  9. #22
    Feb 2004
    Hickory, NC
    A garrett turbo, I knew it.
    Mods
  10. #23
    Jun 2004
    are you sure they spool that fast???? seems too good to be true..
