JDM STI vs Mach1 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on JDM STI vs Mach1 within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I'm positive. The 03-04 Cobras have an Iron block and aluminum heads. Taken from the SVT FAQ.... What are the ...
    Registered User silverscooby's Avatar
    Oct 2002
    Cary, NC
    What are the differences between the 2003 Cobra and the 2001 Cobra?
    Mechanically, the 2003’s have a 112 c.i. Eaton supercharger, intercooler, intercooler reservoir, slightly different heads and cams, 8.5:1 compression, forged pistons and Manley H-beam rods, an Iron block, Tremec T-56 transmission, 3.55:1 rear gears, and stronger half-shafts
    2002 WRX 352whp & 341ft-lbs *SOLD*
    12.5@109
    2004 SRT4 449whp & 457ft-lbs
    11.6@125
    Dec 2001
    McLean, VA
    I have saw a bone stock Mach 1 run a 13.10 107 MPH. Some Mag got it to run 12.9.
    Oct 2002
    Cary, NC
    Yeah, I've seen a 13.2 from a local guy here. FWIW, the one in the video has ran 12.9@107
    12.5@109
    11.6@125
  6. #19
    Dec 2001
    McLean, VA
    Was that your SRT 4 against the Mach1? The 4.10 gers a good for 1/4 mile runs, but suck on the highway.
  7. #20
    Oct 2002
    Cary, NC
    Yeah, that was mine. Not sure what you mean about 4.10 sucking on the highway. Acceleration is acceleration. The higher the ratio the faster the acceleration in any given gear, right?
    Unless you mean he has to shift sooner or the RPMs suck for freeway driving?
    12.5@109
    11.6@125
  8. #21
    Dec 2001
    McLean, VA
    You give up top end with the 4.10 on the highway. I had a 97 Cobra with a Vortech S trim and 4.10 gears. Car sucked on hihgway runs. I could pull on my competition, but after 4 th it died out. I changed them to 3.55 and then 5th became a monster. Top speed with 4.10 was 145 ish and with the 3.55 I hit 160 mph. Also I could pull stronger in 4th with the 3.55.
  9. #22
    Jan 2004
    the stock mach1 i have seen trap anywhere from 104-106 and get et's of 13.3-12.9... the reason is that they have a solid rear with 3.55 gears, a higher compression ratio than the other 4v's and put a a hell of a lot more torque...
    2001 Mustang Cobra
    Vortech @9psi
    13* Timing and 11.5AFR
    Tuned by ME
