yikes! I actually thought the STI was going to make that turn!![]()
This is a discussion on STi vs ............... within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; http://www.bzz.pwp.blueyonder.co.uk/scoobycrash2004.wmv [/URL]...
What a tool! STAY ON THE GAS!!!!
-Fess
05 STi Silver/Silver Goodness!
Is that what he had to do to straighten out? It seems like if he had mashed the throttle once he straightened out, he should have darted forward, rather than go out of control.Originally posted by 1fastsubie
-Fess
I have zero experience with that sort of racing. Except in videogames, so I am curious to know what he did wrong.
'02 Silver WRX
- PDX Tuned Stage 2.5 w/ APS FMIC, ACT Street clutch & flywheel
He caused "snap oversteer" I think he lifted late entering the corner then cut the wheel to the left, then the front tires bit and sooo long. When ever cornering hard if you feel the back comming around it is time to apply power!
My $0.33
-Fess
Seriously i have no idea how he did that. My guess is he hard brake when he turn left, cause he lose control right when he turns. Which I think there is still room for him to slow down before entering the coner. I couldnt be wrong.
At that speed correcting the car is very hard. The steel wheel is extremely heavy, and everything is going so fast i think only very experience driver can pull it off.
One thing for sure, that guy will remember that 2 seconds in the car.
he was probably trying to drift around the corner, but forgot he was AWD.
^^^ WRX is right....I was checking the vid zoomed and slow mo and the guy is gassing it but he has the front wheels pointed towards the WALL!! I believe that he should have had the wheels pointed straight ahead during his "drift". Just my opinion.![]()
Actually his wheels are pointed the right way through most of the corner, his mistake comes right at the end, where he is 75% through the turn. At this point he sould have pointed his wheels straight while giving the car some throttle. He had the right idea through most of the turn, he just forgot to point his wheels straight at the very end, oh well. Honestly though before you go do that kind of racing you should atleast go to a parking lot and mess around with the car, so when you try to drift your 30k+ car you dont run into a wall when you should have clearly made the corner.
-BobbyD
5spd/U/D/MBC/QTEC
Just a costly mistake of not knowing what you are doing.he will learn.
Also,
STi < Ditka
yeah.
Looks like he just got his STi coming from a (or learning on a) RWD drift car. If that had been a RWD car he woulda been fine, but thats the AWD difference right there.
=+- 02' Midnight Black Scooby Rex-+=
I will take the tranny !![]()
my car is slow,,,,,, very slow.
if what you guys said is true, then he must be stupid or out of his mind at that moment. Why would he drift at that couse, except he is in some kind of drifting track day.
I sure would like to learn how to drift. Bondurant (here in Phoenix) had a write up in AutoWeek stating they are going to teach it at their school. From the article, it states that it will be a 2 day course at a grand a day and they most likely will use the GTO.
My guess is he just came in too hot, ended up in a slide, continued to counter-steer, and when he finally got some traction after scrubbing off all that speed from the slide his wheels were pointed at the wall, and bam.
2002 WRX Sedan, Blue.
Catless, Cobb Stage 2, and so on.
