Laid waste to EVERYTHING at the track today! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on Laid waste to EVERYTHING at the track today! within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Just dynoed my car on a dyno dynamics dynometer (same modle Shiv uses) with the following results: Pump gas (94 ...
    Jan 2004
    Rosedale, IN
    Pump gas (94 octane) 311.1 HP @ 6200 RPM and 311 lb/ft of torque @ 4250 RPM.
    My peak power was at 6200 RPM and my boost at that point on the graph was 20 psi. The torque peak at 4250 RPM was at 22 psi of boost. I was spiking up to 23 psi and droping to 19 psi by redline.
    Then I swaped over to the unleaded race gas {(101 MON +109 RON)/2 = 105 AKI octane} and loaded in my race gas map, results:
    332.8 HP @ 6000 RPM and 333 lb/ft of torque @ 4170 RPM.
    At the peak power point of 6000 RPM I was making 21.5 psi of boost and at the peak torque point of 4170 RPM I was making 25 psi of boost. I was spiking up to 25 psi and droping down to 19.5 by redline.
    Keep in mind these numbers are all on a Dyno dynamics dynometer like the one Shiv uses, commonly called "the heart breaker" dyno.... well, lets just say my heart isn't broken
    Using Shivs "dyno equalizer" programe I am making 435 HP at the flywheel on pump gas (equivelent to 366 wheel HP on a dynojet or dynapack) and 466 HP at the flywheel on race gas (equivelent to 392 wheel HP on dynojet or dynapack) . I put the cat back on the car and pulled 322 HP at the same boost level. That would be 452 HP at the flywheel on race gas (equivelent to 380 wheel HP on a dynojet or Dynapack)
    Keith
    Miss the wifes WRX, but love my Ralliart!
    Jan 2004
    Rosedale, IN
    Pump gas sheet:
    Jan 2004
    Rosedale, IN
    Race gas sheet:
  6. #19
    Oct 2002
    Chicago
    evo's are definately putting down some impressive numbers! can't wait to throw my sti on a dyno.
