man those things are beasts.
This is a discussion on SRT4 Encounter within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; A friend and I finally had a chance to get together to run his 2004 SRT4 which is stock against ...
A friend and I finally had a chance to get together to run his 2004 SRT4 which is stock against my Stage 2.5 2002 WRX. We did a few 40-100mph rolls in the 70-80 degrees and each time was basically the same results. We were basically even till 4th gear came and the SRT4 would start to pull slwowy. We shut down each time but I knew it would be over if we continued to play. However once we did a 40mph roll and right around 70mph, there was a longer sweeper turn and I kept WOT and pulled a bus length+ on him because he got off the gas because his rear end was losing traction. I still love AWD because roads are not always straight. It's always fun to run.![]()
2004 STI White/Gold
251whp & 263ft/lbs ( Stock ): 0-60 = 4.8 ( Fastest = 4.1 ) & 1/4 = ?
276whp & 290ft/lbs ( DP ): 0-60 = 4.5 & 1/4 = 12.9 @ 105mph
Have you ever tried runnng Turboxs's high performance boost controller. I picked up .2-.3 tenth in the 1/4 mile by switching to it over the abc boost controller. This was on my Stage 2 WRX. I was running 13.3s @ 100 mph with the high performance boost controller. I only ran 13.5s - 13.7s @ 97 mph with the abc controller.
Their is a noticeable difference in performance.
I was trying to use the ABC instead of a MBC so I can use the UTEC to it's full logging potential. The HPBC is still a MBC thus bypassing the UTEC signals. I'm now adusting the boost gain value ... I have it now at 47 instead of 50. I'm hoping the "quicker" spool up will help. It's still definitely a learning experience.
2004 STI White/Gold
I think I'm going to try that.Originally posted by SGOSWRX
thats pretty interesting chu. Are you sure your car is faster since you went with the UTEC? Because when i raced my friends 04 SRT-4, he could never pull me at all when we were alone in our cars. My mbc was set at like 16.5 psi, it was a boostvalve.com one. I would expect you to pull on him with a UTEC, because i always thought a UTEC would make my car even faster, maybe your friends SRT-4 is just faster than my roomates, who knows.
-BobbyD
5spd/U/D/MBC/QTEC
I know I have more whp and ft/lbs w/ the UTEC as I was dynoing at 213whp w/out the UTEC and dynoed 220whp w/ the UTEC not tunned. Since I've tuned the A/F to 11:1 now so I know I should have even more whp/ft/lbs ... I'm expecting 225-230whp. I know the SRT4s are pulling 230wp+ easily from the factory.
2004 STI White/Gold
I beat an srt-4 pretty easily with my stage 2 set-up
the 2003 srt-4 is 218hp and 230tq i think. the 2004 are 230hp and 250 tq. so maybe u beat the 2003 one. the 2004 ones are beasts from what i heard.
it all depends on the dyno and the conditions that day. Your car can be unchanged but dyno different numbers on different days.
5spd/U/D/MBC/QTEC
Last night I saw a 2003 srt-4 run a 13.2 at 104mph in the 1/4 and all he had was a manual boost control. I asked how he was able to keep the power down without having the lsd and he custom biult motor mounts that lowered the engine. He said it the motor mounts changed the car dramtically. There was a 2004 srt-4 running about the same times but with a aftermarket downpipe and boost control. I was really impressed with the car(first time I have seen it run at the track). There was an evo running in the 12s who did a 1.5 60ft time. -scott
Originally posted by WRX
man those things are beasts.![]()
2003 SRT-4
my friend adams dyno's 249 with an upgraded wastegate actuator, he now reels in stockish LS1's. amazing what 20 bucks can do!
03 MBP WRX Sedan
STi RA gearset October 4th,STi Trans Mount
Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
umm...noOriginally posted by MidnightFLAT4
Stock(ish) ls1s are trapping 105+ even autos...That's a bit hard to "reel in"
2003 SRT-4
SRT4 > PITA![]()
Joe/Flyin' Under The RadarThe Legendary Hammerdown WagonBugeye Mafia #337
