SRT4 Encounter - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on SRT4 Encounter within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; well stock SRT-4's (2004's) are trapping about 102. So with around 20 more whp, i think they are getting close ...
    Registered User BobbyD's Avatar
    Apr 2002
    Indiana
    well stock SRT-4's (2004's) are trapping about 102. So with around 20 more whp, i think they are getting close to LS1 territory. Obviously the 600 pound difference helps .
    -BobbyD
    5spd/U/D/MBC/QTEC
    Registered User StoplightWarrior's Avatar
    Jun 2003
    CA
    -BobbyD
    SRT4's only weigh 2800lbs?!
    May 2003
    2900
  6. #19
    Apr 2002
    Indiana
    Don't most LS1's, besides vettes weigh about 3500 pounds? Maybe i was wrong, but regardless SRT-4's still have a weight advantage obviously.
    -BobbyD
    5spd/U/D/MBC/QTEC
  7. #20
    Mar 2004
    Puyallup, Wa
    I've seen 03's put down 205-228 whp and 04's put out anywhere from 220-245 whp. But i beleive the conditions and dyno play a big part in the drastic differences. Most 03's are usually around 215-220 whp, while 04's are 220-230 whp. Too bad it's all to the fronts though, but it can be fun sometimes
    Jayson
    04' STI/04' Infinity FX35 Stock for now
  8. #21
    Registered User SRT THIS's Avatar
    Jan 2004
    South Side
    Re: SRT4 Encounter
    Originally posted by chuglobal
    A friend and I finally had a chance to get together to run his 2004 SRT4 which is stock against my Stage 2.5 2002 WRX. We did a few 40-100mph rolls in the 70-80 degrees and each time was basically the same results. We were basically even till 4th gear came and the SRT4 would start to pull slwowy. We shut down each time but I knew it would be over if we continued to play. However once we did a 40mph roll and right around 70mph, there was a longer sweeper turn and I kept WOT and pulled a bus length+ on him because he got off the gas because his rear end was losing traction. I still love AWD because roads are not always straight. It's always fun to run.
    Sweet runs, and yeah those 04's have a bit of advantage top end due to the stg 1 injectors they already come with. I went to LACR last week and ran 13.2 at 105mph with a 2.1 60 ft. My buddy took his 04 and ran continuous low 14's but the elevation kills it there. Oh well 15 bucks for like 15 runs isn't bad.
    Stg. 0
    -380hp & 437lbs-
    No NOS
