o sh!t i wantOriginally posted by adam3482p
No its not a reflash. It is a realtime map
Base Map - Refers to any map that is flashed into the ECU.
Real Time - Refers to a Real Time switching map that can be used without flashing the ECU
It is possible to store both a Real Time and Base version of the same map on the AccessPORT at the same time. The Base will be used to flash the ECU. The Real Time version can be used to switch back in the event you've selected another Real Time map.
Copyright, Cobb, 2004
LinkBack URL
About LinkBacks
hahaha
