i am referring to the aspect of bad weather (sliding, spining tires, handling) and also, also, the performance aspect of not losing control or breaking lose.Originally posted by Snacks
"stacks up" is a vague attribute. If you put all of them on the floor and measured their height, or weight, I'm sure their respective differences would be very obvious. What specifically do you want to know? I could make an arguement for any one of them being the best depending on what you consider is important.
LinkBack URL
About LinkBacks
you should probably read up a bit more on that one.
) rather than just redistribute the power to a gripping wheel, the wheel is braked electronically through the ABS system. this equates to a NET LOSS of power, rather than a simple redistribution of 100% of the power.
