Results 1 to 15 of 21
This is a discussion on S2000 from a roll within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Today, I went from a 30mph roll to about 95mph with an S2000. I kept up with him with slightly ...
    Registered User Rich10's Avatar
    Oct 2002
    Long Island
    S2000 from a roll
    Today, I went from a 30mph roll to about 95mph with an S2000. I kept up with him with slightly less than full throttle, shifting at approximately 6000 rpm's. The S2000 then turned off the highway.
    After I let off, I realized that my UTEC was switched to my most conservative setting, 11.5psi maximum boost.
    Is it possible that the S2000 wasn't giving it full throttle or is it that easy to take them from a roll?
    2002 WRX WRB
    Registered User Pirana's Avatar
    Jun 2003
    Somewhere in Time
    Thats funny I did the same yesterday with my friends S2000, but no contest with a STi
    fre
    fre is offline
    Registered User fre's Avatar
    Nov 2003
    Idaho
    May I ask what you have? I want to run into one of those S2000 things
    Jun 2003
    Somewhere in Time
    Stock 2004 STi. He has a stock 2003 S2000. After his beating he says he is going to get the Vortech supercharger.
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    fre
    fre is offline
    Nov 2003
    Idaho
    Oh sorry I meant the original poster, of course you have an sti you said so and of course that makes sense, since that is about the power I am pushing and I would expect to spank one too. That is funny he is going to try the supercharger though... you will probably still spank him lol
    Registered User brembo's Avatar
    Oct 2002
    North Carolina
    Tell him if he does that, all yer gonna have to do is get rid of the cats, throw on a MBC and you'll still be on the winning end. 50 bucks for a JoeP, and 500-800 for a TBE. I'd even offer to buy dinner when ya spank him, since you saved so much money
    2003 WRB Wagon. Vishnu Stage 2(VF30). DBA 5010's/steel lines/Carbotech Bobcat pads, MRT topmount. Tein coilovers, 22/24 mm sways, ALK....I'M DONE!!!!!!
    Oct 2002
    Long Island
    I have an aftermarket uppipe, midpipe, samco hoses, utec, catback and pulleys. If I had been running a more aggressive map such as the 16.5 psi that I usually run, or my leaned out fuel map, I really would have had to lift off the throttle.
    The thing is that on the street, you can never tell if the other car is really trying. From what I have heard, there is a huge difference in an S2000 that shifts at 6,000 and one that shifts at 8,000 rpms.
    2002 WRX WRB
    fre
    fre is offline
    Nov 2003
    Idaho
    So pretty much a stage2+ and you run 16.5psi? Damn, I run that with a VF34 heh. I also agree on the can't tell if they are trying, but who cares they don't try then they lose Er wait you didn't say you even had a downpipe hrmmm.
    Oct 2002
    Long Island
    A VF34 blows more air at 16.5psi than a TD04.
    As for the downpipe, I want to run one cat. By having the cat in the downpipe, I don't have to worry about cat efficiency CEL's. I don't like having a cat in the uppipe. A cat in the midpipe is so far away from the engine that the exhaust gas is relatively cool and the cat is relatively inefficient. Or so I have heard. That leaves the downpipe.
    2002 WRX WRB
    Aug 2002
    SoCal
    You're running 16.5psi on the stock turbo?
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Oct 2002
    Long Island
    Yes, 16.5psi max which trails down to approximately 11 to 11.5 psi by 6,500 rpm's. Although my utec is mapped for closed loop boost vs open loop boost, its a pretty standard TurboXS stage 2 boost profile
    2002 WRX WRB
    Aug 2002
    SoCal
    TXS runs 16.5 on their maps? Sounds like it is really pushing the limits of the TD04. Maybe they just want to sell you a new turbo?
    Oct 2002
    Long Island
    Well, that would force me to upgrade my turbo.
    2002 WRX WRB
    Apr 2003
    Phoenix Arizona
    Just so you know any 2000-2003 S2000 if your racing will shift at 9,000 RPM. Hard to say how hard he was trying. You should beat the S easily at those low speeds. On a highway roll, it would have been MUCH closer.
    293.2 hp to the ground
    267 lb/ft torque to the ground
    VF-30 Setup
