I raced one from a rolling start (5 mph) and beat it pretty bad to 75 mph and then had to shut down due to an oncoming traffic light. I was behind him when the race started and by end of 1st, I was 2 inches away from his bumper. In 2nd gear, changed lanes, and pulled on him like mad. Once I was in 3rd at around 75 mph, I had about 2-3 cars on him. He had a passenger, I didn't.
LinkBack URL
About LinkBacks
) we would run from 55 to 100-110 or so, and he would always pull about a car or so on the top end. And even from the lower gears, he would be able to keep up pretty well until he pulled on the top end. If you're racing an s2000 and they mistakenly shift to early, the race is essentially over. If they shift anywhere below 6500, they're done (they should be shifting at redline). This is even more important in the lower revs, because a modded s2k will most likely spin in the lower gears, so they have to know how to control the throttle in that area of the power band. Nevertheless, the only run I had with a s2k was a supercharged one, and from 50-110 i got him by 1 1/2 cars. When we finished he said he tuned to 310 whp, so I was pretty impressed, since I'm at 320, and he's rwd and a bit lighter.
