Can we run low 13's w/o a new turbo??
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
This is a discussion on Can we run low 13's w/o a new turbo?? within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I just read a post on here about a 84 t type.I will be happy if I can beat a ...
    Registered User WRXwant1's Avatar
    May 2002
    I just read a post on here about a 84 t type.I will be happy if I can beat a stock (or slightly modded) 87 GN.What will it take??Has any one ran hi 12's with the stock turbo??I dont want to do any mods that void the warranty.
    But after 3 years, bigass turbo!!
    Registered User cnoff's Avatar
    Mar 2002
    Denver
    It would take a miracle. You would void out your warranty anyways because of the other mods you would need to get times like that (i.e. BC, Headers, Uppipe, Exhaust, etc). If you're going to do all that, might as well get a bigger turbo.
    2002 Platinum Silver Rex
    Registered User Flyboy's Avatar
    Mar 2002
    9200' Golden, CO
    Re: Can we run low 13's w/o a new turbo??
    Bro, I'm not flaming you but you definitely need to get your priorities in order. What is more important to you right now, beating a Grand National or voiding your warranty? You are not going to get one without the other. You seem to have the attitude that as long as you leave your stock turbo in place you will still have your warranty. That is not correct, there are plenty of things outside of an upgraded turbo that will void the warranty. Something as simple as a cold air intake or exhaust will void parts of your warranty. A lighter/underdriven crank or alternator pulley can void portions of your warranty. The answer is not black and white, there's a lot of room for interpretation. If your Subaru dealer is a jerk and not "open minded" when it comes to mods they will frown upon any aftermarket part that you install in your car.
    2011 SWP Premium Hatchback
    Flapatax Mud Flaps
    Kartboy STS with front and rear bushings
    Cobb AP Stage 1 (for now)
    May 2002
    Well most mods I think I can put back to norm before I goto the dealer E.G. exhaust, intake etc; and only if something breaks.I dont want to change anything that is too hard to revert in a day or two.Are stock GN's that fast.I just want to run maybe a 13.4 & I will be happy.What does that take??
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Grand Nationals are very fast cars, especially if they are worked.
    It is possible to get into the low 13s without upgrading the turbo, you just have to do everything else:
    boost controller, air filter, uppipe, IC hoses, good downpipe and/or turboback exhaust, a Unichip and an upgraded intercooler wouldn't hurt either.
    I'm planning on wringing as much power out of the stock turbo as possible before I upgrade.
    I'm positive that my catless uppipe will put me past my first goal of <13.5s and 100+ mph in the 1/4 mile.
    I will be smashing this goal in mid-July.
    My current best was 13.650s@99.11mph. You can read about my recent runs and my mods below.
    -Jim
    May 2002
    As a matter of fact flyboy, you have the mods that I want to get!!The uppipe seems like the ***** out of the bunch to revert, but if I blew my tranny I think
    I may find the strength to do it !What do you run and can you beat a stock GN??
    May 2002
    Nice time PlatinumWRX with a relatively stock wrx.The only true gains I think come from the MBC.thanks for the info.
    Mar 2002
    9200' Golden, CO
    Believe me, once you install that uppipe you will not want to remove it.
    I have no idea what it runs, I'm probably going to take it to the track after I get my downpipe. I'm just guessing on this but I would say that anything below a 13.6 should beat a stock GN. Anyone with real life experience care to give feedback?
    Flapatax Mud Flaps
    Feb 2002
    Huntingdon Valley, Pennsylvania
    If you want to start beating GN's, and run low 13's its actually VERY easy to run low 13's with the proper mods... A friend of mine ran a 13.3 with just a turboback and MBC... I am not a firm beleiver in the unichip with the STOCK turbo, i think its really unnecassary until your running larger turbos with much larger PSI.. Warranty, well, i could care less about my warranty, but thats just me, the only thing that will void it is if somthing goes wrong that is pertaining to your mods... Like just recently i took my car to the dealer to have them fix my mirror that keeps flipping loosely, dident say anything about my mods, covered the mirror under warranty, and i was on my way... No talks about putting me on there "****list" for having mods or anything.. Just asked me kindly not to cut into the little "Green" wires under the dash because they lead to the conector where the dealer can troubleshoot the car .... U can always jsut take your mbc off when u goto the dealer.. But if you going to do mods and somthing goes wrong, theres no reason they should cover it your takin that risk.. Good luck... MBC turbo back samco hoses uppipe should get you way into the low 13's if you know how to shift
    Rob
    Apr 2002
    SoCal
    I think ive heard somewhere (maybe i-club) of wrx's with stock turbos runnin in the 12's. I know there are some definetly runnin low 13's with stock turbo.
    Not exactly sure, but it rings a bell.
    '00 2.5RS
    Jun 2002
    Bay Area CA
    Do a search on i-club, there is someone who just set a new stock turbo record around 12.5...this is a usa record, there is a guy that ran 11.89 in England...but he is fooling the computer and running 23 psi boost with a custom intercooler and a liqid injection system (INTO the intercooler). His name is cosie convert. His WRX is just to tow his race car!
    Jul 2001
    PA
    This is absolute BS. The stock turbo can NOT produce 23 psi of boost. Maybe it was a VF30 powered WRX STi or similar grey market subaru.
    The US stock turbo record was set using nitrous oxide.
    -Jim
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    -Jim
    Jim, this is a pretty heated debate going on at I-Club...Jorge (Rifts) was the one who told us all about it, but the majority of everyone is pretty much with you on this...
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
    Sep 2001
    You will probably not say that when your transmission starts to fail like so many people on i-club. Good luck on shelling out 2-3 grand when that happens.
    Jul 2001
    PA
    WHO will probably not say WHAT?
    -Jim
