What type of JDM Sti motor is it? What year, is it a type RA spec C, etc etc.
If it's a bone stock regular JDM Sti I would say you're making around 230-250whp. Hard to say really.
This is a discussion on RSTi vs Cobra within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; I recently got my car back from getting the engine swap with an JDM STi engine and transmission. I didn't ...
I recently got my car back from getting the engine swap with an JDM STi engine and transmission. I didn't really know what to expect from the swap, but I knew it would be fast.
The manager at the place that I work has a 95-97 Cobra that is all motor putting out around 370 hp to the wheels. Since I just got my car back I was feeling kind of saucy, so I asked him to race me. I didn't think I would win. I only wanted to see how bad I would lose.
Last night we finally got the chance to race and this is how it turned out. We started from a 30-40 mph roll and he got the jump on me (damn low end torque). He said he went up to around 120 mph before he shut down, and by this time he had about only 2-3 car lengths on me. I was surprised that I wasn't beaten by bus lengths. It was a good race and I hope I can race him again from a stop to see how it turns out.
BTW can anyone guesstimate how much power I am putting to the ground by how close the race was? Thanks.
2002 WRX 352whp & 341ft-lbs *SOLD*
12.5@109
2004 SRT4 449whp & 457ft-lbs
11.6@125
first off, if he's "all motor" then it must be a 5.0...in which case, its a 94 or 95...
second, again, if he's "all motor" he's likely making no more than 300 to the wheels.
Sounds like this guy is "all ricer" to me...I call BS until he posts a dyno sheet.
2003 SRT-4
Stoplight.......I know quite a few 5.0's that are producing well over 300whp all motor. I myself had an 89 LX 5.0 and produced 375whp at a local shop's dyno. So it is not a surpise if his Cobra is producing those numbers. One of my old mustang buddies has an 88 GT and his is laying down close to 400whp all motor and is running mid to high 12's.
2004 WRB Cobb Stage II WRX
220whp 210wtq
man you can produce serious numbers on an all motor v-8 with the right amount of work boring it out will make serious numbers
if its not fast it better be a show car
Why does it have to be a 5.0 if its all motorOriginally posted by StoplightWarrior
Sounds like this guy is "all ricer" to me...I call BS until he posts a dyno sheet.![]()
There are plenty of 4.6 stangs making 300+ na.
I believe Bob Cosby is running low 11's on his na 01 cobra...
2000 Mustang GT - 620hp/500tq
it doesnt have to be, but unless this guy is really into his sh1t, its gonna be a 5.0...also, yes there are 5.0s making over 300na but its hard to do on a street car.Originally posted by v6killer
Why does it have to be a 5.0 if its all motor![]()
2003 SRT-4
If he has 370rwhp na then I would think he is really into his ****Originally posted by StoplightWarrior
Im not arguing that its easier on a 5.0, but I just wouldnt jump to the conclusion that it is one.
He had is motor stroked and bored from 4.6 to 5.0. He went from 320 to 370 whp. I have seen the dyno sheet myself, so I kknow it is legit.
BTW I have an STI V2 555 motor with 2.5 in downpipe, 16g (small), no cats, and running 17psi.
Not to be picky but if it's a Mod (4.6 Origanal base displacment) it has to be a 96 or 97) So really it does take alot to get a Mod motor into that range without a power adder simply because there are NO aftermarket Heads for them. The only ones I've ever seen are PI heads which of O.E. on 99 newer but I think those are for the 2v motor not the 4v in a cobra. I'm not saying it's impossible to put those kind of numbers down in that car, just unlikely w/o a power adder or some sort. If he went N/A he also has alot more money tied up in to it then you do probaly. Oh well I'm really surprise that the cobra gave you that much of a run, watch out for any LS1.
Hell i am running mid 12's with my four banger!Originally posted by jdmpwrdr
and when did this become a mustang forum?
the argument is moot!!!![]()
Stage IV+
Going for 11's
u will win from a stop.
LISC #1
05 STi - 300whp 331wtq 1/4 - 12.7 @107.4 (SOLD)
06 Evo IX 370whp 386wtq (Under Construction)
Just a little fyi,Originally posted by 302@12psi
He said a cobra, you are right about the 96-97gt though. They will need PI or SVO heads to reach low 300rwhp. That's the exact reason why I went with my cobra motor *easier to reach the mark*.
Also 370rwhp is on the lower average for the big bore cars, most are around 400+ but that does include cams. You really don't have to port the heads since they flow very well from the factory. So many things you can do with so little money![]()
Blaiz
32vGT
MOD MAX makes aftermarket cyl. heads for 4.6,
recently made 325 whp with them. stock displacement...regular exhaust modifications...with good cams..
cz
05 SMG M3
04' WRX
01' M5
soontobetwinturboE92
I'm not aware of Modmax making heads. I know they make valvetrain components. It's pretty much a waste to buy heads for a 4.6 though. If you have a 96-98 then you upgrade to 99+ heads/intake. If you have 99+ you get your existing heads ported and add cams *and necessary equipment for them*...this is speaking of the GT only.Originally posted by WRX=Imprezzed
cz
If you have a cobra, you just work the stock heads and add cams *pretty pricey*. Totally off topic, what are 02 wrx's going for used of course? I've been thinking about getting one lately but not sure what to look for.
Blaiz
32vGT
