VW R32 vs. WRX - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on VW R32 vs. WRX within the Comparison: WRX vs World forums, part of the Community - Meet other Enthusiasts category; Originally posted by tan Why it's the same exact Haldex system as the Audi Quattro. Yeah I know and they ...
  1. #31
    Aug 2002
    Yeah I know and they BOTH (4motion/Haldex) need improvement to compete with the Subaru AWD. The Subaru AWD is set up to perform more like a RWD vs the VAG (VW/Audi Group) AWD system that is more like a FWD (apples for apples AWD).
    2002 WRBP WRX
    Old setup = BPM GT turboback, PDE up-pipe, Unichip w/custom map, cooler plugs (NGK range 7), Walbro 255LPH FP, MBC (15 PSI), and custom built turbo utilizing the 13G housing (Internals: Hitachi compressor wheel, Mitsu 15G turbine lightly clipped).
    1/4, 12.88 105.10 - 1/8, 8.09 85.96
    New set up = Now w/UTEC and STI Injectors
    1/4, ? - 1/8, ?
  3. #32
    Aug 2002
    Originally posted by Retro
    Don't dis the non turbo, after all, you need one for the all motor races. Besides, imagine what happens when you do put a turbo on that thing .
    True, but it's far more difficult to do that to a NA vehicle compared to a car that's already designed for it. Personally, I think it's too much work to do that and even then you can't run too much boost due to the compression, etc.
    2002 WRBP WRX
    1/4, ? - 1/8, ?
  4. #33
    Registered User WRXless's Avatar
    Mar 2002
    Kelowna
    I'd suggest that VR6's respond well to turbo setups. Check out http://www.hpamotorsport.com/ . They build their turbo setups using all VW parts.
    Sheppe (aka WRXless)
    '02 Jetta GLS 1.8T
    Jetta Pic 1
    Jetta Pic 2
    Jetta Pic 3
  6. #34
    Aug 2003
    Lemme get this straight.... the Haldex is not as good as the Subaru setup? Are you saying this because its not Full time AWD?
    I think the Haldex (vw/audi) AWD is superior because theres less drivetrain performance loss. its only 2wd unless it detects slippage, then its AWD, and its actuates the AWD instantly. Its not a Viscous fluid system that takes a bit to engage, its electronic, and instantaneous. Isnt that better? If I'm way off here, then I;d like to know what you are talking about.
    -GR
  7. #35
    Registered User VetteVert's Avatar
    Nov 2001
    Boone, NC
    Don't dis the non turbo... Besides, imagine what happens when you do put a turbo on that thing .
    Your wallet gets lighter...QUICKLY. Turbo kits for VR6'ish setups are insane...not to mention if you want to build the bottom end to actually stand moderate boost.
    VV
  8. #36
    Aug 2003
    VV
    Wellll.. I'm not so sure about that either.... The R32 3.2l VR6 supposedly has a few other options availible for it other than the HPA setups.... VF engineering or something like that has a Supercharger for it that puts up 5psi and boosts to over 300hp! For not nearly as expensive as the HPA ingenious packages.
  9. #37
    Nov 2001
    Boone, NC
    True..but he said turbo. SC is always cheaper (slightly overstated). Based on the available options I've seen, the prices are rediculous.
    VV
